HS,
What is the status of Aeon Labs' Home Energy Monitor support in HS3? It was functioning well in HS2, but does not seem to be supported in HS3.
Several issues:
1. 6 child devices get created, when there should be 7. EP1 & 2 power (W), EP1 & 2 Watts Used (kWh), Total Power (W), Total Watts Used (kWh), Battery.
2. Some devices are reading data twice into them (therefore instantly overwriting:
3. Some devices values, specifically Aeon Labs Power Node 2 Child, Aeon Labs Watts Node 2 Child EP1, and Aeon Labs Watts Node 2 Child EP2 never get updated (though their data is getting dumped into the wrong fields, shown above).
4. I get errors on rescans, for example:
Please let me know the status.
-BD
Several issues:
May-22 4:34:46 PM Z-Wave Device: Z-Wave Interface Aeon Labs kW Hours Node 2 Child EP2 Set to 1.123 (1.123 kW Hours Used) May-22 4:34:46 PM Z-Wave Device: Z-Wave Interface Aeon Labs kW Hours Node 2 Child EP1 Set to 1.19 (1.19 kW Hours Used) May-22 4:34:46 PM Z-Wave Device: Z-Wave Interface Aeon Labs kW Hours Node 2 Child EP2 Set to 4125.84 (4125.84 kW Hours Used) May-22 4:34:46 PM Z-Wave Device: Z-Wave Interface Aeon Labs kW Hours Node 2 Child EP1 Set to 4440.72 (4440.72 kW Hours Used)
Node 2, EndPoint=1 Multilevel Sensor Report was not received (B) - the child device will NOT be configured properly.
-BD
