Go Back   HomeSeer Message Board > Telephone,Text and Email Plug-ins > Telephone,Text and Email Integration Discussion
Old March 7th, 2017, 06:20 PM
balpaugh balpaugh is offline
Question Growl Plugin
I'm trying to understand how to add the Growl Plug-In to my HS3 system. Id doesn't show up in the list of Plug-Ins and everything I've referenced talks about some download files. How is it installed?
Thank you for your assistance.
Bryan
Old March 7th, 2017, 07:51 PM
will40 will40 is offline
try here. https://forums.homeseer.com/showthread.php?p=885186
Looks like link for download is still active.
Will
Old March 7th, 2017, 08:12 PM
jlrichar's Avatar
jlrichar jlrichar is offline
I think that was for HS2. Also it had major problems if I recall correctly.
HS3 : HSpro (3.0.0.318) on Win2012 (vm on ESXi)
Old March 8th, 2017, 08:33 AM
richardo's Avatar
richardo richardo is offline
Growl
I use Growl on my system with Prowl on the Iphone.
On HS2 I did use the growl plugin - but on HS3 found it easier to call the growl functions from a script.
I call a script called Growl Message.vb from an event and populate the message:
using Sub or Function = Main & Parameters = Message to send
sub Main (byVal msg_short As String)
Dim url
Dim url_response
url = "apikey=*****************************************&applicatio n=HS3&event=" &msg_short
url_response = hs.URLAction("https://api.prowlapp.com/publicapi/add", "POST", url, "Content-Type: application/x-www-form-urlencoded")
End Sub
The apikey is the key given when registering growl.
Hope this helps.
the past is from where we learn....
Old March 9th, 2017, 02:02 PM
So it's not installed through the Plug-Ins tab in HS3 like other Plug-Ins?
Old March 9th, 2017, 02:11 PM
richardo's Avatar
I haven't found any HS3 specific plugin.
I find that executing growl from the script to be more reliable - I used to have issues with the HS2 plugin where it would freeze and stop sending messages. I did eventually stop using the HS2 plugin and moved to the script method.
Old March 9th, 2017, 04:10 PM
jlrichar's Avatar
As an alternative there is an excellent pushover plugin for HS3. It is not in the updater but is easy to find. IMHO it is way better for notifications to mobile. In addition there is a pushalot plugin that I think is in the updater that is pretty good for notifications to windows 10 clients.
Old March 9th, 2017, 05:30 PM
mrhappy mrhappy is offline
Originally Posted by jlrichar View Post
As an alternative there is an excellent pushover plugin for HS3. It is not in the updater but is easy to find...
It is in the updater now so is even easier to find
Old March 9th, 2017, 07:09 PM
jlrichar's Avatar
Doh! That's right I forgot you got it in there.
Growl plugin jlrichar HomeSeer General Discussion Area 39 March 13th, 2017 12:07 PM
Growl/Prowl Plugin HS3? bartbakels HS3 Plug-In Development 3 November 22nd, 2013 10:38 PM
Growl plugin, any Mac users out there? flic HS2 / HSPRO 17 January 28th, 2012 07:18 AM
Problem with Growl plugin Post-it Script & Plug-In Library 0 April 18th, 2010 05:33 AM
Growl plugin? heatvent Script & Plug-In Library Discussion 1 January 31st, 2010 12:04 AM
