HS3 on linux - Slow command response
    Hey Mark
    i have been using HS3 on windows for quite some time now with fairly good insteon module response.
    about 3 weeks ago i ported to linux (finally!!) and got it running pretty fast.
    but it seems that there is a weird slow response when i send a few commands one after the other.
    when i send the first command it starts right away but the second module will response maybe 30-180 seconds later. i will open 3 or 4 open/close modules at the same time and the 4th will be open about 4-5 minutes later.
    what do you need from me to debug it?
    thanks
    Originally posted by ez1976 View Post
    Hey Mark
    thanks
    there may be an issue with triggers and events; a loop or similar; I did this once and it slowed down hs a lot.
    otherwise you can post a detailed log snippet of the transaction; need to see what's going on during the delay
    Mark
    HS3 Pro 4.2.19.5
      Hey Mark
      i set to close 3 shades. well it didnt take 2-3 minutes this time bust still a good few seconds response between them.
      here is the log:
      https://pastebin.com/ww2g0Jc3
      i will try to recreate the delay tomorrow.
        Well for another reason all together i had to move back to windows.
        i again exported and imported the configuration but the delay is gone.
        i am guessing this has something to do with the port to linux
          oh well. thanks for reporting back.
          Mark
          HS3 Pro 4.2.19.5
            Hey Mark
            considering moving back to linux on a Raspberry pi 3.
            any complains about slow responses?
            should i try the latest version and let you know?
            thanks
              Hey Mark
              thanks
              do real feedback on response. I guess that means its not an issue, otherwise I would have heard.
              give it a go, and report back.
              Mark
              HS3 Pro 4.2.19.5
                sure
                i will time and log starting 3-4 devices at once on both windows and linux.
                  Hi
                  i bumped up an old thread
                  https://forums.homeseer.com/showthread.php?t=178237
                  i did a full check on my normal windows setup with all the triggers, events and devices
                  and a brand new clean install on ubuntu linux with only 3 devices and your plugin.
                  i posted the detailed logs on both setup and saw a huge difference.
