I was running HS3 on Linux but just got a Windows 10 desktop. I installed HS3 on it no problem as well as the Caseta plugin. I added the SmartBridge, and did auto add of all devices which also worked. However when I try to control any, nothing happens. I've rebooted HS3, the SmartBridge, disabled/enabled the plugin. Only once did it turn a light on but then stopped immediately after. I turned debug mode on and this is all you see in the log when you try to control a light. Any ideas?
Aug-21 5:25:16 PM LutronCaseta Debug Receive: ~ERROR,2
Aug-21 5:25:16 PM LutronCaseta Debug ~ERROR,2
Aug-21 5:25:16 PM LutronCaseta Debug SmartBridgeS1 send command: #OUTPUT,20,1,100,00:00:01,00:00:00
Aug-21 5:25:16 PM LutronCaseta Debug Hs trigger Caseta LutronCaseta LutronCaseta Living Room North Pots ref#:6 to value: 100
