Module Crash + Won't Update
    Hello,
    I installed the Caseta module (3.0.0.95) on HS3 (3.0.0.318) running on a HomeTroller S6. For the first day or so it worked great.
    Then I noticed a significant lag with HS3, and decided to log in to the HomeTroller directly. When I logged in, I noticed a Windows crash dialog for the Caseta module. Once I acknowledged the crash, HS3 became responsive again.
    I attempted to update the module to 3.0.0.96, but it either says update failed or (if I turn off the plug-in first), says it succeeded but it remains at the same version level. I've tried a full un-install / re-install of the plug-in as well but that doesn't seem to work either.
    How should I troubleshoot this?
    Ok disable the plugin and update it should work.
    tell me if this solve the problem.
    thanks
      Hi and thanks for the quick reply.
      That did allow me to update the plug-in (now running 3.0.0.96), but unfortunately it's still crashing.
        do you run Windows or Linux? Do you have an error in the log or in the hometroller?
          Yes. Hopefully this helps... It successfully connects on Port 22 for SSH, but won't connect via Port 23 / Telnet:
          <code>
          Aug-25 4:34:06 PM LutronCaseta ERROR Unable connect to the SmartBridgeS1 telnet check the IP address. Error: 192.168.20.86:23....No connection could be made because the target machine actively refused it 192.168.20.86:23
          Aug-25 4:28:21 PM LutronCaseta try connecting to the SmartBridgeS1 telnet IP address 192.168.20.86Port: 23
          Aug-25 4:28:19 PM LutronCaseta try connecting to the SmartBridgeS1 telnet IP address 192.168.20.86Port: 23
          Aug-25 4:28:17 PM LutronCaseta try connecting to the SmartBridgeS1 telnet IP address 192.168.20.86Port: 23
          Aug-25 4:28:15 PM LutronCaseta try connecting to the SmartBridgeS1 telnet IP address 192.168.20.86Port: 23
          Aug-25 4:28:13 PM LutronCaseta try connecting to the SmartBridgeS1 telnet IP address 192.168.20.86Port: 23
          Aug-25 4:28:11 PM LutronCaseta try connecting to the SmartBridgeS1 telnet IP address 192.168.20.86Port: 23
          Aug-25 4:28:09 PM LutronCaseta try connecting to the SmartBridgeS1 telnet IP address 192.168.20.86Port: 23
          Aug-25 4:28:07 PM LutronCaseta try connecting to the SmartBridgeS1 telnet IP address 192.168.20.86Port: 23
          Aug-25 4:28:06 PM LutronCaseta Lutron Smart Bridge Project
          Aug-25 4:28:05 PM LutronCaseta try connecting to the SmartBridgeS1 telnet IP address 192.168.20.86Port: 23
          Aug-25 4:28:04 PM LutronCaseta Connected to SSHS1: 192.168.20.86Port: 22 Succesfull
          Aug-25 4:28:04 PM LutronCaseta Waiting for Login SSHS1: 192.168.20.86Port: 22
          Aug-25 4:28:03 PM LutronCaseta try connecting to the SmartBridgeS1 telnet IP address 192.168.20.86Port: 23
          Aug-25 4:28:03 PM LutronCaseta try connecting to the SmartBridgeS1 SSH IP address 192.168.20.86Port: 22
          Aug-25 4:28:02 PM Plug-In Finished initializing plug-in LutronCaseta
          Aug-25 4:28:02 PM LutronCaseta Initializing done! Ready...
          Aug-25 4:28:01 PM LutronCaseta Starting initializiation. LutronCaseta
          Aug-25 4:28:01 PM LutronCaseta Method Connected, waiting to be initialized....
          Aug-25 4:28:01 PM Info Plugin LutronCaseta has connected. IP:127.0.0.1:51280
          Aug-25 4:28:01 PM Plug-In Interface LutronCaseta is running as a trial, 29 days remaining.
          </code>
            if you have a Lutron Pro you need to turn on the telnet in your lutron apps of your phone
            setting - advanced - integration - telnet support
              That was it! Thank you!
                Welcome have fun with it
