Go Back   HomeSeer Message Board > Telephone,Text and Email Plug-ins > Telephone,Text and Email Integration Discussion > SMS Gateway (3P)
SMS Gateway (3P) Discussions related to the SMS Gateway third party plugin.
Old March 24th, 2016, 02:53 PM
dexterdom dexterdom is offline
Seer Plus
Android phone as a modem
Hi all, I have an older Samsung android phone lying around and was wondering if it would be possible to use it as a modem. Does anyone have any experience with this?
I've tried the USB tethering option (connected to a Windows 7 PC) but it creates a virtual network card on the PC as opposed to a COM port.
Is there an Android app that I can use to create a virtual COM port on the Windows PC?
I understand that this can be done through bluetooth, but this particular phone does not support the serial port profile.
Old March 24th, 2016, 02:55 PM
beerygaz's Avatar
beerygaz beerygaz is offline
Super Seer
The plugin relies on the ability to create a serial port modem supporting the AT command set. If the phone creates a network card that's not going to work I'm afraid.
Author of Highpeak Plugins
SMS-Gateway Plugin
Blue Iris Plugin
Paradox (Beta) Plugin
Modbus Plugin
Yamaha Plugin
Old March 24th, 2016, 03:19 PM
Seer Plus
Hi there,
Yes that's my understanding from browsing the other posts in this forum. I did some more googling and I'm seeing info that suggests that android does not support AT commands, but I thought I'd ask the Homeseer community...
Old March 24th, 2016, 08:41 PM
rmiles7721's Avatar
rmiles7721 rmiles7721 is offline
Actually if you are willing to mess around you probably can. I still have my AT&T line and a GSM phone I'm probably going to be doing just that with.
You can find some good info at:
https://jalalsela.wordpress.com/2015...d-at-commands/
http://forum.xda-developers.com/gala...mands-t1471241
http://stackoverflow.com/questions/8...-android-phone
Definitely not an easy out of the box solution but it is possible.
Old March 27th, 2016, 10:21 AM
Seer Plus
Thanks for the links but to be honest it's more work than I'd like to try
I think I'll just pick up a cheap gsm modem for now.
Cheers
Old March 27th, 2016, 10:24 AM
beerygaz's Avatar
Super Seer
If you get a modem, be sure to get one that supports your carrier's frequency band. Many of the cheap ones on eBay are 900/1800 only and that won't work in the US.
Old March 27th, 2016, 11:38 PM
Seer Plus
Yes totally aware of that but I definitely appreciate the advice! I just ordered a Huawei E173 modem from Amazon.ca (I'm in Canada) which seems to have the right specs to work with your plugin. As soon as I get it I'll let you know how it works out.
Cheers
Old April 21st, 2016, 10:45 AM
Seer Plus
I just wanted to follow up on this. I finally received the Huawei E173 modem and it works great. I can send and receive messages using your plugin.
The only trick was figuring out which COM port I needed to specify, since the modem presents 3 virtual ports to the OS. For the record, the right port is listed as "HUAWEI Mobile Connect - 3G PC UI Interface" in the device manager.
This is on Windows 7 64-bit.
Old April 21st, 2016, 11:51 AM
beerygaz's Avatar
Super Seer
I'm glad it's working for you, this looks like a cheap solution and you could probably use the E173 for a backup data connection too.
Old April 30th, 2016, 05:44 PM
rmiles7721's Avatar
I may have to fool around with this. The family is on AT&T while I am using Project Fi but I still have a line and extra phone on AT&T I don't even use. I may have to take the old Nexus 6 out of the box and start fooling with it.
New Android Phone Default Project macromark HS3Touch Clients - Android 3 February 1st, 2015 04:15 PM
HS3 Pro Trial to connect with Android Phone? Conrad_Turbo HS3 / HS3PRO Discussion 7 December 11th, 2014 12:54 PM
Android Tablet and Phone Sync langenet Off Topic 15 March 6th, 2014 10:11 AM
Using Android Phone for wall mounted HST jjsmd Clients - Android 1 March 10th, 2012 09:09 AM
