Originally posted by mrhappy
View Post
What's your coolest, favorite, or most approved Home Automation event/rule?
Originally posted by rprade View PostYes, I looked at it. I am considering the device, but it is large, industrial looking and seems a lot more expensive than the others.
Originally posted by freeon View PostHow did you accomplish this. This is one the items on my to-do list.
Take a look at phlocation plugin. Tandy can chime in more because he has taken it to the next level in a lot of ways. I am using the plugin with my iPhone's and doing basic checks on things for AC and locks based off location. I have the system polling phone location every 10 minutes or forcing a poll on the phones when the garage door is opened to speed up the check of us being home and running events.
Originally posted by AshaiRey View PostThe highest WAF i got is a virtual device called 'migraine switch'
If that one is activated by voice or any other way then there will be no audio throughout the whole house, no doorbell, no phone ringing, nothing. When friends do call by phone they get a friendly answer that my wife has migraine. Anyone else calling is directed to a voice box.
For Android, there is Backitude for location and EGIGeozone for fencing. There is beta support for location data through EGIGeozone and Paul has been working on his own app for location/fencing for Android, but the last I heard was Android 6 has huge location services problems. I do not know if the Android applications support iBeacons.
I am not an Apple fanboy and Apple location services have their share of problems. That said, I have been completely satisfied with the GeoFency/native iOS pair. With the two services working together it is very reliable, has modest impact on the battery life and provides a world of data.
I have been wanting to put together a post describing what all I do with the two services together, but haven't had the time. Leveraging the symbiosis between the two services and adding iBeacon support is where you get the real power.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Love Android?
Then the this one :http://store.homeseer.com/store/Task...HS3-P2081.aspx rules them all
Eman.TinkerLand : Life's Choices,"No One Size Fits All"
Originally posted by rprade View PostLike Wayne said, I use PHLocation. In my case it is with iOS support for location (position) and GeoFency for fence/iBeacon support.
Originally posted by AndroidDev01 View PostHave you ever tried a Aeon Labs ZW078-A? It appears to be designed for this task specifically.
Originally posted by mikee123 View PostIs it possible to get or calculate a power used today from the Aeon Labs ZW078 ? Like I can from a RFXcom Owl electricity sensor for example ? I am using a Owl sensor to measure power going into my immersion, and a RFXcom virtual device to add up power used today, but its so inaccurate. I guess that the diameter of the wires is to thin
Sure. I might take some virtual devices to hold data and a script to do the math, but totally doable.
Originally posted by waynehead99 View PostI also have an issue with the dogs and the doorbell. I use an ardiuno tied to the door bell that controls a relay. We can control if the doorbell rings or not. Either way I also I have it set to send a text to the wife and I if someone presses the button. Really nice if we are in the back yard and expecting guest.
I have some of the lights around the house tied to the weather to turn on if the clouds start rolling in. I have found this to work better than trying to use a light sensor for my needs. I also have house modes for schedules, but this allows the lights to come on earlier on days it's raining.
Also, what's a good way to detect a doorbell has rung? I don't care about shutting it off, but detecting it so I can send a Pushover alert or speak via Homeseer speaker / Sonos would have good usefulness.
My current favourite that goes down well is that my alarm clock is pulled from a calendar on a Google Calendar. It then sets the Sonos speakers to an alarm if the alarm goes off, that is fairly standard stuff.
At the same time the alarm hits the location of my place of work hits the Bing Maps API, it then pulls off a route and a time for this route. If it is over a specified amount of time (35 mins) then I light up a hidden LED red that I will see when I wake up and that gives me a tell tale sign to pick another route or spend less time in the shower.
I could reverse the two and set the wake up on the back of the commute time but not sure I trust my VB that much!
Originally posted by robertb View PostBoth of these sound quite interesting. I use a "turn on lights x before sunset" event, but as you've mentioned, I'd like to have some ability to generate it when clouds dark us up early. Any further detail on how you've implemented this?
As far as the doorbell, I wrote up what I did at this link:
http://board.homeseer.com/showthread.php?t=178869
Some of my (and wife's) favorites are:
1. Automatic Dog Bowl Fill - I use a sprinkler valve controlled by HS to push water through for 15 seconds 4 times per day. Only have to clean bowl every few weeks.
2. Automatic Pool Fill - Another Sprinkler valve triggers based on Z-wave water sensor. Keeps water at correct level even though original pool system did not include an automatic fill.
3. Close Secret Bookcase door to Home Theater Room and automatically close drapes whenever alarm is set. This means anyone outside cannot see inside and cannot even get into Home Theater Room even if they get inside unless they know how.
4. Brighten front porch light if someone steps onto porch - Simple motion sensor and event to provide additional lighting to identify people at night or to provide better visibility for us to unlock the door when we return to the house.
5. Automatic Hallway Light Following - Motion sensor triggers events to turn on hallway and certain other common area lights.
Now I have to go investigate some of you guys other ideas!
Vector
I keep the lights outside dimmed as well unless the garage door is opened, then the house goes into full bright mode outside for 15 minutes after the door has been closed. I travel a lot and make sure the wife doesn't walk into a dark area when going into the house.
Most of my lighting is done on a schedule even if we are not home. Mainly because the wife thinks the dogs need light in the evenings... Go figure.
