How do you setup an event to trigger when the alarm is going off? I can't seem to find the documentation. I assume if I put in unspecified it should work, but I can't really pinpoint just the alarm's actual trigger.
Event Trigger
Originally posted by tome10 View PostHow do you setup an event to trigger when the alarm is going off? I can't seem to find the documentation. I assume if I put in unspecified it should work, but I can't really pinpoint just the alarm's actual trigger.
Can't help you with your second question, that's a panel config, Matt should be able to help there.
Z
You've asked two questions here. What exactly are you trying to achieve.
Your zone/sensor that controls your entry/exit point should be put in Group 13 which will then allow you to determine the amount of time between trigger and alarm activation. All achieved directly from the control panel.
Settling up an event to carry out a command in the event of an alarm condition is quite straightforward. The alarm panel and it's zones/sensors are just devices as far as HS3 is concerned. A basic example assuming you have a zone/sensor named Frontdoor and a device called Light and you want to turn the light on in the event of the Frontdoor being tripped
If Frontdoor changes and becomes faulted
Then Set Device Light to On
Again I'm not really sure what you're trying to achieve but the condition of the zones/sensors are either normal or faulted so use these parameters to set up the logic of your events.
I was asking for the trigger to have a push notification sent when the alarm is going off. Then, the comments that suggested I'd have different triggers for the different zones seems to require excessive event building. Maybe I should just build a single event to push when the siren is wailing? Do people really put an event for every zone to do this? There's 30 Zones. I'd think there would be something that tells HS the alarm is wailing, and this ____ is what triggered the event. I'm new forgive my ignorance.
So about the group 13 thing. I looked in the plugin's control page and found the listing of the zones. Is the group 13 the Zone Type? I notice the previous owner's/installer's put the doors in Zone Type 10, and the windows and break sensors in zone 13. So I need to find the command to lengthen the delay before wailing of group 10. That sounds easy enough.
Originally posted by tome10 View PostI was asking for the trigger to have a push notification sent when the alarm is going off. Then, the comments that suggested I'd have different triggers for the different zones seems to require excessive event building. Maybe I should just build a single event to push when the siren is wailing? Do people really put an event for every zone to do this? There's 30 Zones. I'd think there would be something that tells HS the alarm is wailing, and this ____ is what triggered the event.
Z
Originally posted by vasrc View PostAgain, it depends on what you define as an "Alarm". Triggers exist for all of the individual devices (zones?) so, if you're referring to an "alarm" when any device changes state (ie door/window - open/closes), yes you'll need to create an event for each as there's no ALL zones alarm sent from the Concord unless it's armed. If you want an alarm when the system is Armed, you can figure out which device set it off by pulling the HS3 device value from the "Last Changed" device. I have a simple script that will do that for you.
Z
Originally posted by concordseer View PostVasrc how about Panel Status. If all Concord Devices are Normal and one or more changes does Panel Status change to reflect this.
Script below:
Z
Public Sub Main(ByVal Parm As Object)
Dim AlarmType, Parms() as String
Parms = split(Parm, ",")
' Change device string if it's been renamed'
Dim LZname as String = "System Last Zone Faulted"
Dim LZref as integer = hs.DeviceValueByName(LZname)
if (LZref > 0) then
Dim dv as Scheduler.Classes.DeviceClass
dv = hs.GetDeviceByRef(LZref)
Dim ZoneName as String = dv.Name(hs)
Dim emsg as string = Parms(0) & " received for " & ZoneName
hs.SendEmail("TOemailaddress","FROMemailaddress","CCemailadd ress","BCCemailaddress","Alarm Recieved",emsg,"")
end if
End Sub
Originally posted by vasrc View PostYou're correct, using the Panel Status and a script, will give you the device/zone that caused the alarm. This will only be for devices/zones and not other alarms.
Script below:
Z
if (LZref > 0) then
hs.SendEmail("emailaddress1","emailaddress2","","","Alarm Recieved",emsg,"")
end if
End Sub
I'll check this out when I'm back in the house.
Originally posted by tome10 View PostI was asking for the trigger to have a push notification sent when the alarm is going off. Then, the comments that suggested I'd have different triggers for the different zones seems to require excessive event building. Maybe I should just build a single event to push when the siren is wailing? Do people really put an event for every zone to do this? There's 30 Zones. I'd think there would be something that tells HS the alarm is wailing, and this ____ is what triggered the event. I'm new forgive my ignorance.
https://www.manualslib.com/manual/84...s.html?page=46
Originally posted by tome10 View PostSo about the group 13 thing. I looked in the plugin's control page and found the listing of the zones. Is the group 13 the Zone Type? I notice the previous owner's/installer's put the doors in Zone Type 10, and the windows and break sensors in zone 13. So I need to find the command to lengthen the delay before wailing of group 10. That sounds easy enough.
Script below:
Z
if (LZref > 0) then
end if
End SubHW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
Originally posted by TeleFragger View Postso all I have to do is save this as a .vb, change TOemailaddress to the actual email address? then set the event to run script?
Add another event for "Ready" if you want to be notified when it clears.
Note: since this retrieves from the Last Status Field, it may get the wrong device if there are a lot of alarms generated at the same time and HS3 is running on a slower device.
You might also want to AND on some conditionals (ie Away/Armed, etc) to keep it from triggering every time a door is open/closed
Personally, I have separate events for many of the Zones since I want to manage them separately (ie delays, alarm, trigger other events)
Z
