Go Back   HomeSeer Message Board > Pool Controller and Interface Plug-ins > Pool Controller and Interface Discussion > AquaConnect (3P)
AquaConnect (3P) Discussions related to the AquaConnect pool controller.
Old May 14th, 2015, 04:24 PM
happnatious1's Avatar
happnatious1 happnatious1 is offline
Heater status and setpoints
Im' converting my pool to salt this year and I bought the equipment with homeseer in mind. I have the plugin talking to my ps4 through the 232 thingy(as you can tell I'm new to this) and I can control my heater from the settings menu, however shouldn't I see a heater status and heater setpoint in those devices? Not 100% sure I have all the configurations set right. I'm pool only with 1 hayward heat pump heater.
Old May 14th, 2015, 06:35 PM
jbbtex's Avatar
jbbtex jbbtex is offline
If I recall correctly, I had to change the label of my heater in the AquaConnect control panel to "Gas Heater" in order for the plug-in's heater control/status devices to work properly.
Brady
Old May 15th, 2015, 08:12 AM
Thumbs up
Thanks Brady, That was it!
Old May 15th, 2015, 06:21 PM
Mister2t Mister2t is offline
Seer Plus
Thanks for the assist jbbtex!
The Plugin was programmed to look for Heater1 label = "Gas Heater" on the actual pool controller.
Old May 15th, 2015, 09:42 PM
Seer Plus
happnatious1,
I added a "Spa" configuration option to allow you to disable to Spa section and associated devices. You can try it out by disabling Aquaconnect from the Manage Plugins screen and then replace the HSPI_AQUACONNECT.exe file with the new compressed version I just added to this thread...
http://board.homeseer.com/showthread.php?t=174354
Then reenable the Aquaconnect plugin.
Let me know how it goes.
Mike
Seperate Heat and Cool setpoints? yzpmpgq BeakerStat 0 November 5th, 2012 12:33 PM
Storing Setpoints for later use... footVOL ZWave 0 January 21st, 2010 03:56 AM
heater status ? snowboarder DooStat 1 December 2nd, 2007 10:00 AM
Controlling setpoints from a script petez69 UltraM1G HSPI 0 July 31st, 2007 08:17 AM
Default setpoints with RC80 Thermostat cotropia HAI/OnQ Panel (HS2) 1 September 27th, 2004 11:18 AM
