mcs Temperature does not seem to be properly updating (or causing the update) of the "Last Change" timestamp in HS. I visually see my temperature devices change but the timestamp in the Last Change column doesn't.
Currently I have temp sensors that haven't changed according to HS in 1.5 hours even though the database confirms they have changed several times in that period.
Among other things am guessing the last change column is the only way to know I may have a bad sensor when I check the option to "Use Previous on Bad Reading".
