Originally posted by mnsandler
View Post
Not sure if this is related to the addition of the sensitivity level, I suspect one of those weird kinks but here goes.
After updating to .37, I was erroneously expecting a new link to show up (I now know it's a setting). So I did a "Reprogram device for HomeSeer': I ended up with duplicate links. So I then deleted all links and did another "Reprogram device for HomeSeer': no links would display, I tried this a few times. I turned on detailed logging and did another "Reprogram device for HomeSeer': finally the links appeared.
The 'battery level' channel and the new 'light level' channel have no associated link but they do appear as HS3 devices.
Thanks for adding the 'sensitivity level'. Now the challenge is to determine which level produces the right result.
