Hi folks,
I am testing the UltraGCIR3 plugin with the Itach IP2IR device so far with fairly good results, however I am having an issue when using the IR blaster:
I have saved a few IR codes to channel 1:3 (blaster output) and have setup the blaster to be a couple of feet away from the device I am trying to control.
The good news is that when I test this setup using the "IR Control" tab in the plugin the device in question responds correctly.
However when I try to control the very same device with the IR control configured and linked to a HSTouch button, there is no response. I have included screenprints of the setup below.
Please note that when the same setup is done using 1:1 or 1:2 (non blaster), the IOS client is able to control the IR device.
Any help would be appreciated.
mrwassen
PS: I have tried to restart everything (both plugins as well as the server itself) but this doesnt not help
mrwassen
