Unable to communicate with the Insteon powerline interface
    Is my PLM dead or has something else gone wrong? We had a power outage and when the system came back up I noticed that none of my insteon devices were responding to homeseer. I did a clean reboot of the system and I am still having the issue. On the Insteon plug-in page it says:
    ** Unable to communicate with the Insteon powerline interface ***
    Please make sure the interface is configured correctly and restart the plug-in.
    Log snippet:
    Jun-01 8:01:21 AM TTS Speak ():Web server port number is 8088
    Jun-01 8:01:20 AM TTS Speak ():Welcome to Home-Seer
    Jun-01 8:01:20 AM Speaker Speaker host added, Name: Esgaroth Instance: Default IP address: 127.0.0.1
    Jun-01 8:01:01 AM Starting Plug-In Plugin Insteon started successfully in 4250 milliseconds
    Jun-01 8:01:01 AM Insteon Could not contact Interface on COM3
    Jun-01 8:00:57 AM Info System connected to MyHS Service successfully with license ID 99967.
    Jun-01 8:00:57 AM Info System connected to MyHS Service, waiting for acknowledge...
    Jun-01 8:00:57 AM Startup Start up complete.
    please try a factory reset on the plm. see the manual for instructions. Then you can use the reprogram interface routine on the config page of the plugin.
    Mark
    HS3 Pro 4.2.19.5
      Thanks Mark!! That did the trick.
        always like the easy ones! thanks for reporting back.
        Mark
        HS3 Pro 4.2.19.5
