Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > MCS Plug-Ins and Scripts > mcsSprinklers
  #41
Old December 12th, 2017, 11:40 AM
langenet's Avatar
langenet langenet is offline
OverSeer
So it's off season for me with regards to irrigation. Running 2.17.0.19, if I restart HS for any reason, I always need to manually deactivate McsSprinkler after each reboot. Otherwise, I wake up to errors with the zones not responding (my rainbird is powered off during the winter).
Is there anyway to persist the fact that a seasonal shutdown has been invoked?
Robert
HS3PRO 3.0.0.435 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dot, WS+, WD+ ... on and on.
  #42
Old December 26th, 2017, 10:22 AM
aldo's Avatar
aldo aldo is offline
Super Seer
Hi Michael, I'm getting the same issue, restarting the plugin will re enable the season shutdown option.
Aldo
  #43
Old December 27th, 2017, 12:33 AM
Michael McSharry's Avatar
Michael McSharry Michael McSharry is offline
OverSeer
I am testing V2,18 now that shares the same executable between Windows and Linux. I will make certain I cover this.
  #44
Old December 27th, 2017, 09:47 AM
aldo's Avatar
Super Seer
Quote:
Thanks, happy holidays.
Aldo
Sent from my SM-G935V using Tapatalk
  #45
Old January 14th, 2018, 11:29 PM
OverSeer
Don't know if it has always been this way, but I suspect something may have changed with HS that is causing this behavior. With HS versions of mcsSprinklers the management of devices is handled by HS. This assures that only one master exists for the content of a device. This means that when HS shuts down and then restarts I expect HS to restore the content of devices at the time of startup. I suspect what has happened is that HS no longer manages the initialization of plugin devices and it expect the plugin to initialize the startup condition. I can understand this philosophy and will accommodate. It also means that there are other devices (e.g. inhibit tomorrow) that are not being initialized correctly with HS3.
HTML code is Off
McsSprinker not adhering to seasonal shutdown all the time langenet mcsSprinklers 2 May 18th, 2017 03:40 PM
Problems with Win 8.1 wmark BLRF (3P) 12 January 23rd, 2015 02:13 PM
X10 PLM Problems pbibm Insteon Plug-in (Mark Sandler) 4 November 25th, 2011 02:59 PM
DB Problems.... Bestgear BLRadar (3P) 4 May 3rd, 2011 06:26 AM
X10 Problems keef General Home Automation Hardware Discussion 2 October 9th, 2006 02:18 PM
