Go Back   HomeSeer Message Board > Energy Management Plug-ins > Energy Management Discussion > APCUPSD Plugin (3P)
APCUPSD Plugin (3P) Discussions related to the APCUPSD UPS monitoring plugin.
Old February 5th, 2017, 01:38 AM
Mr_Resistor Mr_Resistor is offline
Seer Deluxe
APC UPS on Synology?
Has anyone gotten this monitoring the APC on a Synology NAS? Synology is supposed to support NUT.
My home is smarter than your honor roll student.
Old February 5th, 2017, 09:23 AM
pcp pcp is offline
Super Seer
I don't have a Synology, but if you enable debugging on the plugin we might be able to get a bit mode insight. Does it connect and can you post the HS3 log from the plugin when it poll the UPS for updates? Note the HS3 plugin is windows only.
Old June 12th, 2018, 12:12 PM
stefxx's Avatar
stefxx stefxx is offline
Seer Master
I like to connect to the NUT server running on my Synology as well. I already run WinNUT on the HS3 machine to make sure it shuts down properly, and that works. However, I had to add a username and password to the configuration file like this: MONITOR ups@192.168.1.111 1 monuser secret slave
monuser/secret are the default userid/pwd on the Synology NAS. Without this, WinNUT doesn't work. So I think I need to supply this info to the plugin as well, however I don't see where I can enter this info...
Any suggestions?
stefxx
Old June 12th, 2018, 01:40 PM
stefxx's Avatar
Seer Master
Never mind, it works now. Not that I changed anything... still wondering why it works without credentials...
HTML code is Off
HS3 on Synology Greg B HS3/PRO Beta Releases 53 June 1st, 2018 10:31 AM
Synology Plugin? Sireone HS3 Plug-In Development 61 January 6th, 2018 10:50 AM
Synology NAS DSteiNeuro Personal Computers 11 October 30th, 2015 05:30 PM
Synology? Sireone iTunes DAAP (3P) 1 October 26th, 2015 08:34 AM
SqueezeCenter Plugin for Synology Viper1970 SqueezeBox Plug-In (3P) 0 July 1st, 2009 09:11 PM
