Go Back   HomeSeer Message Board > Energy Management Plug-ins > Energy Management Discussion > APCUPSD Plugin (3P)
APCUPSD Plugin (3P) Discussions related to the APCUPSD UPS monitoring plugin.
Old May 16th, 2015, 02:11 PM
CFGuy's Avatar
CFGuy CFGuy is offline
Have A Blessed Day
Time Left device
I hadn't updated for several versions and did so yesterday.
I had a couple of events setup that looked at the value of the time left device. They were set to trigger if the value went below 300. After upgrading those events started triggering. I'm pretty sure you were storing the number of seconds as the device value in previous versions. Now the device value is always 0.
Did this change in newer versions?
Jeff Farmer
HS 3.0.0.312, HSPhone
Other Plugins In Use: APCUPSD, EasyTrigger, FBitSeer, HSTouch Server, Kinect, PHLocation, Pushover, RFXCom, UltraGCIR3, UltraMon3, UltraPioneerAVR3, X10, Z-Wave
Hardware: GoControl Irrigation Controler, Schlage Lever Lock, Schlage Deadbolt, Way2Call Hi-Phone, RFXCom RFXrec433 Receiver, WGL 800, TI-103, Z-Net, Pioneer 1120, Pioneer 1021, Panasonic BDT-110, Panasonic BDT-210 x2
Old May 16th, 2015, 04:17 PM
pcp pcp is offline
Super Seer
I check and not intentional, i.e. still want to save the value on the device as the number of seconds.
Old May 16th, 2015, 06:05 PM
pcp pcp is offline
Super Seer
I found the issue and a regression I introduced. I sent version 3.1.0.4 to HS for the updater.
Old May 16th, 2015, 06:50 PM
CFGuy's Avatar
Have A Blessed Day
Thank you!
set time to device string supergee Programming with HomeSeer 3 January 4th, 2006 07:04 PM
Time on Elk-M1G off by an hour, when ElkRP left running MrOcelot General M1 Discussion 1 October 3rd, 2005 02:54 PM
Another Challenge: An Ebay 5 minute TTS warning for the time left to bid jwilson56 Script & Plug-In Development 21 December 9th, 2003 06:43 AM
