Go Back   HomeSeer Message Board > Energy Management Plug-ins > Energy Management Discussion > APCUPSD Plugin (3P)
APCUPSD Plugin (3P) Discussions related to the APCUPSD UPS monitoring plugin.
Old March 15th, 2016, 07:53 PM
bobpak bobpak is offline
APCUPSD HS Plugin Failure
After downloading the subject plugin, it appears in the list of plug ins with an OK status. The Instance column says to See plug-in config. The config screen is as follows...
Error: System.InvalidCastException: Conversion from string "60.0" to type 'Integer' is not valid. ---> System.FormatException: Input string was not in the correct format at System.Int32.Parse (System.String s) [0x00000] in :0 at Microsoft.VisualBasic.CompilerServices.IntegerType.FromStrin g (System.String Value) [0x00000] in :0 --- End of inner exception stack trace --- at Microsoft.VisualBasic.CompilerServices.IntegerType.FromStrin g (System.String Value) [0x00000] in :0 at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger (System.String Value) [0x00000] in :0 at HSPI_APCUPSD.HSPI.get_UPSUpdateInterval () [0x00000] in :0 at (wrapper remoting-invoke-with-check) HSPI_APCUPSD.HSPI:get_UPSUpdateInterval () at HSPI_APCUPSD.hspi_config_page.GetPagePlugin (System.String PageName, System.String user, Int32 userRights, System.String queryString) [0x00000] in :0
APCUPSD on my Win 10 PC installed and configured without a problem and displays UPS status detail when the systray icon is executed.
Thoughts?
Bob
Old March 15th, 2016, 11:42 PM
pcp pcp is offline
Super Seer
Did you enter 60.0 into the update interval configuration? Can you try to entrr 60 instead of 60.0?
Old March 16th, 2016, 12:13 PM
Phillippe -
I'm a bit confused...the Poll Time in WINAPCUPSD is set to 60 (not 60.0). I'm not sure if that is what you are referring to or how I get to the "update interval configuration" parameter in the HS APCUPSD plugin.
Bob
Old March 19th, 2016, 03:07 PM
pcp pcp is offline
Super Seer
OK I understand what could produce this. It will be fixed in the next version.
Basic and/or Creative Events created with APCUPSD plugin TomTom APCUPSD Plugin (3P) 18 February 21st, 2016 11:59 PM
Is there a script or Wifi connect plugin? when power failure Malosa HS3 / HS3PRO Discussion 0 September 6th, 2015 11:15 AM
HS3 ZWave plugin crashes on power failure Blade HomeSeer Z-Wave Plug-in 9 May 20th, 2015 12:12 PM
APCUPSD Script beerygaz Jon00's plugins and scripts 3 October 10th, 2010 07:28 AM
ELK Plugin failure jeremylaurenson Elk M1 Plug-In 3 November 22nd, 2006 05:36 AM
