Go Back   HomeSeer Message Board > Energy Management Plug-ins > Energy Management Discussion > APCUPSD Plugin (3P)
APCUPSD Plugin (3P) Discussions related to the APCUPSD UPS monitoring plugin.
Old August 30th, 2016, 01:43 PM
amr42's Avatar
amr42 amr42 is offline
Unhappy Using APCUPSD plugin on PC already using another apcups daemon
Is there anything that would stop me running the APCUPSD plugin on a Windows Server 2003 R2 O/S that is already monitoring a remote UPS connected to another device via port 3551.
So the existing APCUPSD runs fine and monitors UPS just fine, shutdown config, etc.
HS3 APCUPSD plugin Config is - Host = hostname of remote device, port = 3551.
When I try to connect the device from the HS3 Home page it disconnects after about 10 seconds. No event data is populated, nor plugin status fields (except connected - briefly)
Help!
Old August 31st, 2016, 04:29 AM
zwolfpack zwolfpack is offline
If I understand your configuration, I think it should work.
I'm running two UPS and three instances of apcupsd. My desktop is connected to one via USB, my hometroller is connected to the other via USB, and my z-net is slaved off the hometroller. All three can be monitored by the plugin [although the z-net one is of questionable value; it's a repeat of the hometroller data and the status device is wrong -- it always reports "charging"].
Couple things to check,
- in the apcupsd.conf's, make sure you have NISIP 0.0.0.0
I think that is the default for windows, but on the rpi (znet) it is 127.0.0.1, which would prevent anything but the z-net itself from connecting.
- try specifying the IP address rather than the hostname as a test.
Attached is my status page
Old August 31st, 2016, 06:28 PM
amr42's Avatar
Thanks! Got it working by specifying Server = 127.0.0.1 So I think that the APCUPSD plugin is actually slaved off of the apcupsd that is running on the Windows server that HS3 is running on rather than via a slave listening on port 3551 from the device with the UPS directly attached.
Minor niggle - where can I find this missing file?
Aug-31 18:34:32 Warning File does not exist: I:\Program Files\HomeSeer HS3\html\images\apcupsd\status\battery_100.png
Old September 1st, 2016, 01:27 AM
On my system (hometroller S6), that file is a shortcut to
C:\Program Files\HomeSeer HS3\html\images\HomeSeer\contemporary\battery_100.png (attached).
Do the other files in your I:\Program Files\HomeSeer HS3\html\images\apcupsd\status\ directory show up correctly? See attached view of 1st part of my directory.
I'm curious, since you are monitoring a slave instance, if the 'status' device shows accurately? For my slave instance, that device always shows 'Charging', even though 'battery change' shows at 100%. And the master instance shows correct.
Sorry if this post looks like a trainwreck.
Old September 1st, 2016, 05:07 PM
amr42's Avatar
Thumbs down
I only have these files:
Old September 2nd, 2016, 06:14 AM
Looks like you are missing the six that are shortcuts. Wonder if this is due to you using a 'non-standard' install location --I:\Program Files\HomeSeer HS3 rather than C:\... Maybe an installer problem? I'd ask the plugin author.
Old September 3rd, 2016, 07:46 AM
pcp pcp is offline
Super Seer
In the apcupsd image directory and per ui theme (classic or contemporary) is a script to build the current icons in the status directory. Some are copied from the theme directory, some are symbolic link to other files (to standard HomeSeer images typically). Battery_100.png is a symbolic link to the standard HS3 battery_100.png icon. One. Reason to use links instead of copying files is that if the standard HS3 icon changes, the plugin uses it as well.
Regarding the in initial question about having multiple clients connect to port 3551 to get updates from apcupsd, that works perfectly. I yip ally have the standard apcupsd client running along with this plugin. Especially or plugin testing, I have multiple HS3 each with the apcupsd plugin connecting to the same apcupsd or NUT service running on the different PCs./NAS.
Old September 13th, 2016, 09:29 AM
amr42's Avatar
I don't think I can create shortcuts as .png files (only .lnk files). So I just copied them over (remembering of course (NOT)) that if default images change to repeat this process...
Old September 13th, 2016, 10:02 AM
sparkman's Avatar
sparkman sparkman is offline
You'll need to copy them every time you update the plugin as the plugin's update process will delete all the files in that directory first. I had the same issue when I was running XP.
Cheers
Al
APCUPSD HS Plugin Failure bobpak APCUPSD Plugin (3P) 3 March 19th, 2016 03:07 PM
Trigger of apcupsd devices sparkman APCUPSD Plugin (3P) 15 March 15th, 2016 10:25 PM
Basic and/or Creative Events created with APCUPSD plugin TomTom APCUPSD Plugin (3P) 18 February 21st, 2016 11:59 PM
HS3 with Fire Daemon as a service johnny_holden HS3 / HS3PRO Discussion 1 May 29th, 2014 05:29 PM
APCUPSD Script beerygaz Jon00's plugins and scripts 3 October 10th, 2010 07:28 AM
