Go Back   HomeSeer Message Board > Energy Management Plug-ins > Energy Management Discussion > APCUPSD Plugin (3P)
APCUPSD Plugin (3P) Discussions related to the APCUPSD UPS monitoring plugin.
Old April 10th, 2017, 10:39 AM
Pete's Avatar
Pete Pete is offline
APCUPSD on Ubuntu Linux 64 bit
@PCP
I understand that the plugin was written to work in Windows.
It is showing up here in the HS3 Pro Linux plugins manager list so I installed it.
I did not see any errors in the logs when installing.
I have installed Nut and using generic USB-HID nut driver with the APC UPS (USB).
This is what I see using the nut driver:
HomeSeerPro:~# upsc ups
Init SSL without certificate database
battery.charge: 100
battery.charge.low: 10
battery.charge.warning: 50
battery.date: 2001/09/25
battery.mfr.date: 2006/01/25
battery.runtime: 1305
battery.runtime.low: 120
battery.type: PbAc
battery.voltage: 26.9
battery.voltage.nominal: 24.0
device.mfr: American Power Conversion
device.model: Back-UPS NS 1250
device.serial: JBxyz
device.type: ups
driver.name: usbhid-ups
driver.parameter.pollfreq: 30
driver.parameter.pollinterval: 2
driver.parameter.port: auto
driver.version: 2.7.2
driver.version.data: APC HID 0.95
driver.version.internal: 0.38
input.sensitivity: medium
input.transfer.high: 139
input.transfer.low: 97
input.transfer.reason: input voltage out of range
input.voltage: 124.0
input.voltage.nominal: 120
ups.beeper.status: disabled
ups.delay.shutdown: 20
ups.firmware: 7.g1 .D
ups.firmware.aux: g1
ups.load: 0
ups.mfr: American Power Conversion
ups.mfr.date: 2006/01/25
ups.model: Back-UPS NS 1250
ups.productid: 0002
ups.realpower.nominal: 780
ups.serial: JBxyz
ups.status: OL
ups.test.result: No test initiated
ups.timer.reboot: 0
ups.timer.shutdown: -1
ups.vendorid: 051d
HomeSeerPro:~#
Enabling the plugin I see no graphics for the variables, logs are being written to the root directory using backward slash instead of forward slash, it appears to be enabled then disables itself. I see some of the above data in the variables for a short time.
It is understood that the plugin was written for windows.
I am just checking it out for Linux.
Automator
HS3 Pro & Lite Edition Beta 3.0.0.4449
Old April 10th, 2017, 10:56 AM
mwolter mwolter is offline
Pete,
I've been using it on a SEL with Ununtu 14.04 and MONO 3.28 and it appears to work fine. Images didn't appear on the devices but all functionality appears to be good for the past month or so. Tested by unplugging the UPS from the wall and all statuses were reported to the devices.
Old April 11th, 2017, 12:09 PM
Pete's Avatar
Thank you Matt.
Noticed too that when installing the plugin the zip file was removed.
I would like to install the graphics and maybe just do that manually.
The logging still needs to be fixed as it is writing outside of the Homeseer directory; here it creates a Homeseer directory in the root but cannot write to it after it starts.
IE: Homeseer here is in the root.
/HomeSeer/Logs/
It writes:
\Homeseer\Logs\
Old April 12th, 2017, 08:10 AM
pcp pcp is offline
Super Seer
The plugin is windows only. I contemplated supporting Linux but not at this point and no ETA (if ever). If it shows up as a linux plugin in HS3 on linux I need to discuss this with HST as they control the configuration. They had to fix this once in the past, sorry for the confusion if any. Thanks.
Old April 12th, 2017, 03:07 PM
Pete's Avatar
Understood Philippe and thank you for the info.
Yes; it should be removed from the Linux plugins list.
BTW there are many automation newbies on the forum here that have started automating using the original Zee and currently the Zee-2 (RPi).
WeatherXML V.50 issues in Linux Ubuntu Pete WeatherXML 4 August 16th, 2016 07:34 AM
What version of Mono are folks using for their Linux Ubuntu HS3 Builds? Pete HS3/PRO Beta Releases 11 November 8th, 2015 12:39 AM
Homeseer 3 Pro 171 on Ubuntu 64bit Linux Wave Files Pete HS3/PRO Beta Releases 0 May 14th, 2015 08:31 AM
APCUPSD Script beerygaz Jon00's plugins and scripts 3 October 10th, 2010 07:28 AM
apcupsd monitor script BootsC5 Script & Plug-In Library 2 May 11th, 2008 09:53 AM
