Go Back   HomeSeer Message Board > Energy Management Plug-ins > Energy Management Discussion > APCUPSD Plugin (3P)
APCUPSD Plugin (3P) Discussions related to the APCUPSD UPS monitoring plugin.
Old April 8th, 2018, 06:44 AM
NL-Frank NL-Frank is offline
Viewer
Question No information of the UPS in Status nor in Devices
Dear all,
No information of the UPS in Status nor in Devices. UPS connected to host HS3 through USB.
Operating System:Microsoft Windows XP Professional - Work Station
OS Version: 5.1.2600 Service Pack: 3.0
HS3 Pro Edition 3.0.0.368 (Windows)
APCUPSD version 3.2.0.5
UPS : APC BX700U-GR (connected via USB)
127.0.0.1:0 is enabled
All devices show green icons, Last Change: 21-5-1929, 11:00:00.
Status page via plug in page:
Property UPS 1
UPS Name
Host 127.0.0.1
Port 0
Connected True
Hostname
Model
Mode
Nominal Power
Nominal Input Voltage
Nominal Battery Voltage
Status
Status Flags Not available
No data from the UPS in the Status page, nor in the HS3 devices (seem to be generated properly).
The device also seems to be "offline":
Offline
APCUPSD UPS1 Status 21-5-1929 11:00:00
I've tried everything, somehow I'm overlooking something? Please advice!
With kind regards, Frank.
Old April 8th, 2018, 07:48 AM
pcp pcp is offline
Super Seer
Originally Posted by NL-Frank View Post
Dear all,
Property UPS 1
UPS Name
Host 127.0.0.1
Port 0
Connected True
Hostname
Model
Mode
Nominal Power
Status
Offline
Per aboove the port is set to 0. Can you check in the settings for the UPS configurtion that the port is set to 3551? I suggest setting the host to localhost if the local machine instead of the lookback IP address. Als check any firewall that might block TCP/IP communication with port 3551 on the host. Does the apcupsd icon in the try let you view the status and monitor the host with the same hostname and port?
Old April 8th, 2018, 12:45 PM
Viewer
Solved
Main problem was that I thought that apcupsd driver was part of powerchute, It is not. You have to install seperatedly. My misunderstanding.
If you read the manual it says use port 0 for USB and local, if you install apcupsd it becomes clear what port to use, it is not "0".
What strikes me is that the pluging really stated: connected , so I thought I was on the right track:-)
It is working now, indeed very easy, thanks for your response and the great app!
Regards, Frank
[Feature Request] Modernize Changing Status Information on Devices Ltek HomeSeer General Discussion Area 4 January 20th, 2018 01:07 PM
[script] Composite Device Status - status multiple devices in one vDevice Ltek Script & Plug-In Library 0 July 12th, 2017 02:16 PM
Changing Status Information on Devices - in bulk? Ltek HS3 Scripting 0 May 17th, 2017 05:08 PM
Where to find detailed value information for Insteon devices Jon Insteon Plug-in (Mark Sandler) 6 December 30th, 2015 02:15 PM
Virtual Devices Information bradleygarand HomeSeer General Discussion Area 2 December 26th, 2011 10:34 PM
