Another clear 24 hours - fingers crossed.
Insteon error in plugin
Originally posted by IanIreland View PostAnother clear 24 hours - fingers crossed.
how frequently were you getting errors before?Mark
HS3 Pro 4.2.19.5
Originally posted by IanIreland View PostAnother clear 24 hours - fingers crossed.Mark
HS3 Pro 4.2.19.5
Originally posted by IanIreland View PostAt the moment all is good, I did however have a HDD failure which caused some issues - thank a deity of your choosing for backups!Mark
HS3 Pro 4.2.19.5
Originally posted by IanIreland View PostNo Insteon errors in the log today.Mark
HS3 Pro 4.2.19.5
Originally posted by Minneapolis Mark View PostEverything was fine for a couple of days, mostly when update .24 was in place. Now I have loaded .28 and it's going down a LOT. No responses for at least 5 hours today.
Also, please free to start a new thread for different topics.Mark
HS3 Pro 4.2.19.5
Insteon not working
Woke up this morning and Insteon isnt working. Any ideas?
Insteon Plug-in Error Log Generated 6/20/2018 05:58:34
-----------*Error Message*----------------
Error: Error in Hub.GetResponseCallback: The remote server returned an error: (403) Forbidden. -- Details System.Net.WebException: The remote server returned an error: (403) Forbidden.
at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
at Insteon.Support.Hub.SocketPortClass.GetResponseCallback(IAsy ncResult AsynchronousResult) -- 6/20/2018 05:58:34
--------*Initialization Log*--------------
6/20/2018 05:58:34 - Host System: 10.215.81.4 (House) 3.0.0.435
6/20/2018 05:58:34 - Plugin HSPI_Insteon.exe version: 3.0.6.30
6/20/2018 05:58:34 - Insteon Support library (Insteon.dll) version: 1.0.6.30
6/20/2018 05:58:34 - RegisterCallback Completed
6/20/2018 05:58:34 - Enter InitIO
6/20/2018 05:58:34 - Enter InitPlugin
6/20/2018 05:58:34 - Global initialization of plug-in required, starting up.
6/20/2018 05:58:34 - Initializing Insteon hardware interface...
6/20/2018 05:58:34 - In ProcessRawReceiveThread
6/20/2018 05:58:34 - Initializing Interface...
6/20/2018 05:58:34 - In PLMBuffer_ProcessBufferThread
6/20/2018 05:58:34 - Sending http://10.215.81.130:25105/1?XB=M=1
6/20/2018 05:58:34 - Sending command 02 60 to Interface, (Expecting 6 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Originally posted by mworsnop View PostWoke up this morning and Insteon isnt working. Any ideas?
https://forums.homeseer.com/showthread.php?t=196335Mark
HS3 Pro 4.2.19.5
Ok guys I'm back up with Insteon
Still didn't receive the "update" from Insteon, but found that you can force the Insteon hub back to a previous version (in my case, version 1004, but it's not selectable) Follow the following steps:
Restore Insteon Hub Firmware
•Disconnect Insteon Hub from power
•Press and hold set button on the rear of Insteon Hub while reconnecting power
•The moment Insteon Hub begins to beep, release the set button
•Tap the set button five times. Insteon Hub will beep rapidly and begin the firmware restore process.
•After three minutes, disconnect Insteon Hub from power. Wait 10 seconds and then reconnect power.
•Insteon Hub will automatically re-update its firmware at 2AM. You can manually update firmware from the Insteon app by tapping Update Hub from Edit House in Settings.
Now, I need to figure out how to prevent the hub from trying to update itself. If I can do that, I'm back in business.
