Inseon Help - Plugin will not connect to Hub
    Get message in the log file and in the Plugin management screen. Cannot control Insteon from HS.
    From plugin management: WARNING: Please check the Interface and enter the Interface Port information on the Config page and restart HS.
    From log: ** An error occurred in this plug-in. The details have been written to the log file - C:\Program Files (x86)\HomeSeer HS3\Config\Insteon Error Report.Log
    Jun-23 10:22:34 PM Insteon Error, an error log file could not be written: System.IO.IOException: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\Config\Insteon Error Report.Log' because it is being used by another process. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost) at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost) at System.IO.StreamWriter..ctor(String path, Boolean append) at Insteon.Support.Utilities.LogManager.ReportError(String Msg)
    Jun-23 10:22:34 PM Insteon ** To request help with this problem please post this log file to the forum along with a detailed description of what lead to this problem.
    i think your hub just got the 1016 update which breaks the plugin
    please see
    https://forums.homeseer.com/showthread.php?t=196335
    Mark
    HS3 Pro 4.2.19.5
