Well i included my powernode 6 and it created 19 child devices. So far so good.
Got 6 sets of a binary switch, a watts meter and a KW/hours meter.
However the KW/hours meter is showing the actual watts used at that moment. e.g a device is reporting to use 97watts (checked with a separate meter) and it shows as "96,600 kW Hours Used" and when i switch of the outlet the total drops to 0
Everything seems to point out to that the KW/hours and watts are mixed up. This is with every one of the 6 outlets.
How can i fix this or is a zwave plugin update needed?
Im running HS3pro with the 3.0.0.136 zwave plugin.
