Really need an uninstall
    Hi Blade,
    How do I uninstall this and get my old icons back??
    Best,
    Jakob Sand, I automate everything!
    I'm not sure about this plugin but many of the newer plugins can be removed using the add/remove programs or programs and features control panel applet. Otherwise you could just disable the plugin via the Setup > Interfaces tab.
      In your homeseer 2/bin/blicon folder you should find an uninstaller.
      Marty
        no uninstaller in the /bin
        Best,
          I did disable it under interfaces but icons has not changed back to original icons
          Best,
            If you do not reset them then they will not change unless you have another plugin changing them.
