After several months of messing with the RC-2000 I can now say with some confidence that it is NOT compatible with the HAI thermostat plugin in Homeseer.
If you want a good standalone thermostat, or one to hook up to an HAI system, I highly recommend the RC-1000/2000. If you want to hook up to Homeseer, I recommend you steer clear.
After several months of different DB9 pinouts, I am now confident I have the right connections. My last test today was to use an entirely new cable path, including new cat-5 and RJ-45->DB9 adapters. No success. I also got a replacement RC-2000, with newer firmware, and one that has not exhibited strange symptoms like my first one. This did not help the HS2 connectivity unfortunately.
I've also purchased a PCI Serial adapter to rule out the USB->serial adapter. That did not help. So after sinking about another $50 in trying to get this to work over 3.5 months, I'm finally giving up until someone tests this further and/or updates the plugin to officially support the Omnistat2's.
I'm anxious to hear if/when someone else has positive results. I've also not opened up a ticket with HS, but will probably wait until one or more users actually have the RC-2000 before heading down that route.
The bad thing is that I just purchased a new home security system and went with a GE Caddx. I likely would have gone with an HAI OmniLT to ensure integration with my thermostat (but at a cost of probably $200+ more than what I paid for the GE). But I held out hope that I could get the RC-2000 working with HS2.
Good luck to whoever tries to get this working... and PLEASE post your success here if you get it working!!!
UPDATE!!! The plugin DOES work. The HAI documentation is wrong. System baud must be set to 300 too.
Ben
Ben
