Zee S2 will not restart after Lutron Hub restarts
    Hometroller Zee S2 will not restart after reboot. normal the Zee will restart fine. I the Lutron smartbridge pro hub updates or restarts, for example changes ip address, the ZEE will not restart and continually recycles threw errors: "Unable Connect to the SmartBridgeS! SSH check the ip" it then follows with the correct IP address and can not connect. This has happened before, norrmaly i would reinstall the HS3 software and start over. I would like to fix this so that every time my Lutron Hub updates I do not have to go threw this.
    Thank You
    With the last ver. Desable the ssh in the config, Lutron did change the SSH so it don't work anymore, I'm working to fix it with the SSL so now only the pro is working with the telnet
