Originally posted by mwaite
View Post
Jon00 Database Charting Utility for Homeseer 3 & Homeseer 4
Originally posted by Malosa View Postjon i got a problem
First of all merry christmass to you and all other forum members !!
Ok jon , i installed everything , it run thhe exe and create devices with the demo running but showing no images ... looks like he dont find them...
I also put the demo on 0 and deleted everything and edited my config Jon00DBChartingCreate.ini
Data1= $dva:I3
Data1Label= temp bathroom
it creates 2 charts i dont know why (Chart 001 and Chart 002) Chart 001 is nothing... and Chart 002 is the image , but not showing
with right click the image and open in new window i get 404 Bad Request: /images/jon00/dbchart/chart002.png?time=145908
if i delete ( ?time=145908 ) the image is there,,, what im doing wrong ?
File does not exist: C:\Program Files\HomeSeer HS3\html\images\jon00\dbchart\chart001.png?time=151900
What browser are you using? The ?time=145908 is the method used in browsers to prevent an image being cached (stored) and exactly the same method as that used when you disable caching in HS3.
Please try viewing the device management page on another web browser and let me know the result.
Hi jon!
used ie , Mozilla, safari. All not work , i only see THE broken image , so blank on the virtual .Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
Last edited by Malosa; December 26, 2014, 05:45 AM.Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
Originally posted by jon00 View PostYes, you are right, I've just tried it on .96 and get the same issue. I'm on .147
So i update iTPreferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
OK i Will update in a few hours , i will report back
Thx !Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
Jon,
i have done like described in the pdf file.
Checked if the .dll files are in the folder itself the root folder and they are there.
But when starting the jon00.exe file it crashes a few seconds later.
System i am trying to run it on is win 7 X64 (home premium i thought it is)
HS 3.0.0.97
This is the log that windows points me to.
<?xml version="1.0" encoding="UTF-16"?>
@namespace html url(http://www.w3.org/1999/xhtml); :root { font:small Verdana; font-weight: bold; padding: 2em; padding-left:4em; } * { display: block; padding-left: 2em; } html|style { display: none; } html|span, html|a { display: inline; padding: 0; font-weight: normal; text-decoration: none; } html|span.block { display: block; } *[html|hidden], span.block[html|hidden] { display: none; } .expand { display: block; } .expand:before { content: '+'; color: red; position: absolute; left: -1em; } .collapse { display: block; } .collapse:before { content: '-'; color: red; position: absolute; left:-1em; } <WERReportMetadata><OSVersionInformation><WindowsNTVersion>6.1</WindowsNTVersion><Build>7601 Service Pack 1</Build><Product>(0x3): Windows 7 Home Premium</Product><Edition>HomePremium</Edition><BuildString>7601.18409.amd64fre.win7sp1_gdr.140303-2144</BuildString><Revision>1130</Revision><Flavor>Multiprocessor Free</Flavor><Architecture>X64</Architecture><LCID>1033</LCID></OSVersionInformation><ProblemSignatures><EventType>CLR20r3</EventType><Parameter0>Jon00DBChartingHS3.exe</Parameter0><Parameter1>1.0.0.0</Parameter1><Parameter2>54999d96</Parameter2><Parameter3>Jon00DBChartingHS3</Parameter3><Parameter4>1.0.0.0</Parameter4><Parameter5>54999d96</Parameter5><Parameter6>f</Parameter6><Parameter7>aa</Parameter7><Parameter8>System.InvalidOperationException</Parameter8></ProblemSignatures><DynamicSignatures><Parameter1>6.1.7601.2.1.0.768.3</Parameter1><Parameter2>1043</Parameter2><Parameter22>0a9e</Parameter22><Parameter23>0a9e372d3b4ad19135b953a78882e789</Parameter23><Parameter24>0a9e</Parameter24><Parameter25>0a9e372d3b4ad19135b953a78882e789</Parameter25></DynamicSignatures><SystemInformation><MID>13F1F4FB-385E-4941-8D1E-7AD410793F74</MID><SystemManufacturer>To Be Filled By O.E.M.</SystemManufacturer><SystemProductName>To Be Filled By O.E.M.</SystemProductName><BIOSVersion>P1.80</BIOSVersion></SystemInformation></WERReportMetadata>
And this is another piece :
Tasker Plugin / Speech Droid
Tonlof | Sweden
Try to update to .149 i need to do that aswell
Kind regards
HS 3.0.0.97
And this is another piece :Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
HS 3.0.0.97
Please update if you can and then copy the 3 new homeseer dll files into your Homeseer 3/bin/Jon00DBChart folder.
