best approach for a polling plug-in
    I am looking for the best approach to run an inifinite loop within a plug-in to periodically check the status of a network device.
    the sample .net plug-in with the SDK uses a timer which i have gotten to work for checking my status.
    i tried just initating an infinite loop (with a waitsecs) in the InitIO function, but this just hung the plug-in and HS.
    any other approaches worth investigating
    Mark
    HS3 Pro 4.2.19.5
    You just have to launch a new thread from InitIO(), and do your loop inside the thread. You can use the Thread.Sleep() method to wait between polls.
    stipus
      What's wrong with the timer?
        just looking for alternatives
        probably nothing.
        but as you know, there is always more than one what to do something with these computers. just wanted to see my options.
        programmically, a thread might be a little cleaner as I can keep all my monitoring code together in the thread routines, whereas with the timer, the declarations have to in one place and the monitoring coded in the timer_elasped routine. just a guess at this point however.
        thanks for the feedback
        Mark
        HS3 Pro 4.2.19.5
          Why reinvent the wheel, DooNetwork already does this. When you say poll a network device, I assume you are talking about computer equipment.
          T.
          _________________________________
          Staying on the cutting edge is EXPENSIVE
            i am thinking about building a plug-in that uses a different technology to monitor more than just online/offline status
            Mark
            HS3 Pro 4.2.19.5
              preventing HS from polling a plugin device
              If I set the deviceclass .misc property with the MISC_STATUS_ONLY bit then the device is not polled; this is what i want.The downside is HS removes the stnd on/off buttons of the device.
              I don't really want to add custom on/off back to the device.
              how can i have on/off btns and prevent hs from polling the device?
              Mark
              HS3 Pro 4.2.19.5
