Originally posted by Steve Q
View Post
How To Issue Washer - Dryer Alerts Using Energy-Aware Z-Wave Devices
Originally posted by macromark View PostIt's $19.99 with FREE shipping now!
Got to love Canadian pricing for this stuff...HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Cheers
AlHS 4.2.8.0: 2134 Devices 1252 Events
Mine came in today and added fine to the Z-Net. I already had a gen2 on my network for whole house HEM.
Question about current sensors - Must you clamp it around the hot lead only? Can you clamp it around the entire washer/dryer cable?HS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
Originally posted by rmasonjr View PostMine came in today and added fine to the Z-Net. I already had a gen2 on my network for whole house HEM.
Cheers
Originally posted by sparkman View Post$53??? Mine was $19.99 + $11 shipping to Canada (including one other item) which equates to about $43...
Cheers
Al
Thanks. I'll try amazon.comHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Items: $24.99
Shipping & handling: $9.48
Total before tax: $34.47
Estimated tax to be collected: $0.00
Import Fees Deposit $1.25
Order total: $35.72HS 4.2.8.0: 2134 Devices 1252 Events
Thanks Sparkman. Those are of course in U.S.... I just placed the order and noticed it went up as well.
I will not be able to upgrade to HS3 until after January, in the meantime, this should work with HS2 right?
RobHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Originally posted by sparkman View PostYou can't clamp it around both conductors as current travels in the opposite direction on the other conductor which cancels out the current detected. Needs to be around one conductor only. With the dryer, if it's an electric dryer, you really would need two clamps to measure all of the current flow. If the intent is only to detect if it's running, not how much power it uses, you can clamp it around the neutral as it will have the return current for the motor which would run at 120VAC, not 240VAC. If the outlets are dedicated circuits, you could install it in the breaker panel instead as it will be easier to clamp around an individual conductor there.
Cheers
AlHS4Pro on a Raspberry Pi4
Originally posted by langenet View PostThanks Sparkman. Those are of course in U.S.... I just placed the order and noticed it went up as well.
Rob
Cheers
Originally posted by spud View Postor even simpler, use the EasyTrigger: This device's value has been in range [0,2] for exactly 60 seconds
I think I am missing something simple here. I would imagine that I would choose the "Easy Trigger: A Device's Value is..." trigger. From there I only see two sub triggers:
1. "The device's value was and becomes..." and
2. "Comparison between 2 devices etc etc"
The first one only allows me to choose a device and then choose -2147483648 from both the "was" and "becomes" drop downs. Is this functionality implemented some other way or perhaps my Easy Trigger install isn't working correctly. I am currently on PI version 3.0.0.13 on HS 3.0.0.206 on Win 10
Cheers
Jamescheeryfool
Cheers
James
So I just go my aeon energy reader and I had a question about the z-wave (I'm not overly comfortable with z-wave yet). While still on HS2, I was wondering, do I need to poll the device to get the energy reading? If so, what rate would you suggest. The CCE plugin just reads the meter - I believe the energy readings are real time with the CCE but not so with the AER.
