I finally upgraded to HS3 and I'm setting up everything - in the process I've replaced a few switches that were having communications issues.
I replaced my devices in the ISY with new switches and the devices in Homeseer reflected the new addresses with the original device codes. Everything seemed good. (or so it seemed?)
So I restarted HS and then renamed the devices in the ISY. When I did that, HS/the plug-in created new devices (with the new names) with new device reference numbers in Homeseer. It did not delete the old devices and the old devices now list the original Insteon addresses from the replaced switches. Should I delete them manually? Or should the plug-in "clean-up" and remove the old ones? I get the warning if I try to delete them that it may be best to let the plug-in manage them.
Do you have a best practice for replacing devices in the ISY with the easiest damage control in HS?
Tim
Tim
