Unable to download and install plugin on zee2
    The problem started about a week ago, I only have the HStouch, Z-Wave and Global Cache Plugins installed. I had the BLring plugin installed and tried to update to version x.x.18 when error messages began. I then uninstalled and tried a fresh install (though the manage plugin screen). Same results. I then tried a random free plug in and got the same error message:
    Jul-22 8:51:25 AM Updater Error saving the downloaded file: error
    Jul-22 8:51:25 AM Updater Error downloading package HSPI_Buienradar.exe:An error occurred performing a WebClient request.
    Jul-22 8:51:25 AM Updater Downloading update: Buienradar
    Jul-22 8:51:25 AM Updater Starting download of updates
    Any suggestions?
    thanks so much.
    System Info:
    Current Date/Time: 7/22/2017 9:05:51 AM
    HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.318
    Linux version: Linux HomeTrollerZeeS2 3.18.11-v7+ #781 SMP PREEMPT Tue Apr 21 18:07:59 BST 2015 armv7l GNU/Linux System Uptime: 0 Days 0 Hours 25 Minutes 36 Seconds
    IP Address: 192.168.X.XX
    Number of Devices: 190
    Number of Events: 117
    Available Threads: 399
    Enabled Plug-Ins
    5.0.0.56: Global Cache Pro
    3.0.0.68: HSTouch Server
    3.0.1.130: Z-Wave
    Just a guess.....I have not seen this issue....
    - how much space do you have left on your SD card?
    - have you updated mono stuff (or regular updating)?
    - you can remove the SD card from your Zee2 and do a check on it via a USB to SD device on another computer running FSCK.
    You could try the long math way looking at an old updater.txt file (from a backup of Homeseer) and manually downloading the file if you want. Doing Geoblocking here did have issues with three Homeseer international downloading sites which I had to enable a pass through the firewall a few months back.
    Not related updated both the Zee2 and HSPro machines to Homeseer 3.0.0.342 yesterday. I am still using old Windows V.36 HSTouch clients on the touchscreens.
    No issues that I can see today.
      I think you are right the SD card if full - if I am reading this correctly. I am really using this as a turnkey system so I have not modified anything in Linux itself. I will open a case with homeseer and see how they suggest I proceed.
      homeseer@HomeTrollerZeeS2 ~ $ sudo df -h
      Filesystem Size Used Avail Use% Mounted on
      rootfs 7.0G 7.0G 0 100% /
      /dev/root 7.0G 7.0G 0 100% /
      devtmpfs 460M 0 460M 0% /dev
      tmpfs 93M 216K 93M 1% /run
      tmpfs 5.0M 0 5.0M 0% /run/lock
      tmpfs 186M 16K 186M 1% /run/shm
      /dev/mmcblk0p5 60M 19M 41M 32% /boot
      tmpfs 464M 1.5M 463M 1% /tmp
      tmpfs 464M 156K 464M 1% /var/log
      tmpfs 464M 0 464M 0% /var/tmp
      homeseer@HomeTrollerZeeS2 ~ $ readlink /dev/root
      mmcblk0p6
        Also thanks very much for the reply.
          Yup; looks full. You can just image copy the SD card to a larger SD card then use the raspi-config program to fill the card.
          In Windows just backup to an image and then write the image to a larger SD card using Win32 Disk Imager. (Similiar in Linux).
          Win32 Disk imager is here to download Win32
          First thing to do is to back up your HomeSeer directory. Use WinSCP to do this with HomeSeer in off mode.
          My default MicroSD card here for Homeseer is 16 Gb. Current Zee-2 directory is a 172Mb here.
          I backed up the directory last night before updating from 318 to 342.
          Well just looked and I am using a 32Gb SD card base (really not needed).
          HS3ZeeLite:~# df -l
          Filesystem     1K-blocks    Used Available Use% Mounted on
          udev              874728       0    874728   0% /dev
          tmpfs             178768    5700    173068   4% /run
          /dev/sda1       26916076 9227312  16298428  37% /
          tmpfs             893820     156    893664   1% /dev/shm
          tmpfs               5120       4      5116   1% /run/lock
          tmpfs             893820       0    893820   0% /sys/fs/cgroup
          cgmfs                100       0       100   0% /run/cgmanager/fs
          tmpfs             178768       0    178768   0% /run/user/0
          tmpfs             178768      28    178740   1% /run/user/1000
          Here is the space that my backups show. Note I move them off the SD drive to a NAS box over time.
          HS3ZeeLite:/Homeseer Backups# stat -c "%y %s %n" *
          2016-08-17 01:31:58.048277164 -0500 4096 HomeSeer-252-NOT WORKING
          2017-03-14 08:10:30.005848263 -0500 4096 HomeSeer-290
          2016-08-17 01:39:01.530347463 -0500 4096 HomeSeerZee-2-208
          2016-08-17 01:44:23.311920573 -0500 4096 HomeSeerZee-2-218
          2016-08-17 01:33:40.628778655 -0500 4096 HomeSeerZee-2-218B
          2016-08-17 01:48:17.477065348 -0500 4096 HomeSeerZee-2-255
          2016-08-17 01:40:56.814911060 -0500 4096 HomeSeerZee-2-258
          2016-08-17 01:42:50.747468048 -0500 4096 HomeSeerZee-2-258-B
          2016-08-17 01:35:37.425349644 -0500 4096 HomeSeerZee-2-269
          2016-08-17 01:37:32.397911716 -0500 4096 HomeSeerZee-2-269-ZW
          2016-08-17 01:50:21.853673394 -0500 4096 HomeSeerZee-2-280
          2016-08-17 01:46:29.632538123 -0500 4096 HomeSeerZee-2-288
          2017-04-28 00:43:27.701148220 -0500 4096 HomeSeerZee-2-297
            Stupid question -
            while I am waiting for an SD card, is there anything I can safely delete to make room.
              Looking above looks like your base is an 8 Gb SD card.
              Homeseer doesn't really hardly use up any space...IE: mine is at 175Mb.
              Using WinSCP you see order the files in the Homeseer directory according to size.
              Most likely your biggest files are log files. Then probably your update directories might have a bunch of stuff in them. (zip files?).
              Here unless I am debugging mostly try to keep logging to a minimum.
              Double checked here with my Homeseer Pro stuff and see the most large files under logs and updates and data.
              Get a fast micro SD card as they are reasonable today. I would recommend 16Gb.
              Relating to Debian Wheezy or Jessie; google removing extra not needed files. Do not delete software but you can remove a bunch of cached stuff.
              Note once your SD card is full; the OS will not let you do much as it uses cached SD space to do things. IE you might get some errors when you try to do this live / in vivo.
              Easiest boot up your laptop to Ubuntu; use a live USB stick. Then in Ubuntu utilize file manager to clean up your SD card. In file manager you can organize your directory list with the largest files on the top.
              Do not try to update Homeseer anymore as you will end up corrupting your SD card.
                Bingo,
                We have a winner. I do not use a PC, just a chromebook at home and I sshed in and poke around the directories. The ring plugin had stopped working and I enabled detailed logging - the log file was over 4 G. I had turned off energy logging a long time ago, so there was no issue there.
                Thanks so very much, I appreciate your help. My system is much faster now also.
                latest after deleting log
                rootfs 7.0G 2.5G 4.2G 37% /
                /dev/root 7.0G 2.5G 4.2G 37% /
                tmpfs 186M 20K 186M 1% /run/shm
                tmpfs 464M 116K 464M 1% /tmp
                tmpfs 464M 104K 464M 1% /var/log
