Is it posible to switch a plcbus appliance modul (R2267E) with a X10 4 scene module without the PLC bus 4808. I thoug that when I use the plcbus plugin the 2 signals (X10 and PLCBUS) where connected. But I need to write a event to switch the plcbus module with X10. I have also a multimedia remote that sends X10 signals. And with that remote I can switch the plcbus module on and of without using the events. Can anyone expain that a'm doing wrong ??
X10 and plcbus
peter smithTags: None
You have to create an event on received X10 to switch on/off the PlcBus module. You should NOT use the same house/code device/code for the X10 Scene module and the PlcBus module.
I bet this works fine with your X10 RF remote because the RF plugin you are using is configured to send a power line signal on RF reception.--
stipus
peter smith
x10 and plcbus
Stipus, thanks,
it works fine now, but what I don't understand is, that I can't use for instands "B6" X10 and "B6" PLCBUS. The X10 and PLCBUS electrical signals on the powerline are different so I tought that they didn't interfere with each other. Can you explain why I can't use B6 with X10 and PLCbus ???
Thanks, Peter
