Go Back   HomeSeer Message Board > Ultilities (Plug-ins) > Utilities Discussion > SDJ-Health Plug-in (3P)
Old September 30th, 2017, 05:35 AM
SteveMSJ SteveMSJ is online now
Version History
SDJ-Health Version History
Version : 3.0.5.6
• Updated device images to sdj-health.png.
Version : 3.0.5.5
• Changed the Device Type of SDJ-Health monitoring devices to support the Plug-in API property to improve selection on the Device Management page. Existing devices are updated on first run of this update.
Version : 3.0.5.4
• Added the last battery change date in battery history lists.
Version : 3.0.5.3
• Corrected some minor bugs which affected Local Settings overrides.
Version : 3.0.5.2
• Corrected a bug in writing discharge rates to the SQLite if your system uses ‘,’ for the decimal separator.
Version : 3.0.4.9
• Default polling interval changed to 360 minutes for new installations only. If you are upgrading and use the polling method for any devices then I would suggest you consider whether the polling interval that is set is shorter than necessary. Default was 60 minutes. You can change this globally from ‘Plug-ins>SDJ-Health>Config’.
• Device configuration SDJHealth tab – Re-coded as there was a small possibility of confusion if you clicked on ‘Set All to Global’ and then moved away without Saving or Cancelling.
• Device configuration SDJHealth tab - Additional Information added. Reference IDs and Monitoring Method. Full battery history list in scrollable region if you have Log to Database selected. Button for trimming (deleting) stored history data for the individual device.
• Config Page - Additional parameter added to restrict the maximum number of stored battery readings for each device when logging. This prevents the database growing indefinitely. Click ‘Trim Now’ to trim the full database immediately, however each devices stored data is trimmed if necessary each time a new value is added.
• Clicking the ‘History’ button on a device now cycles back and forth between the normal details and the battery history, if logging is selected.
Version 3.0.4.8.
• Installation and updating now uses updater_override.txt method.
• SDJ-Health Guide added to //Docs folder.
• Optional logging of battery levels to SQLite database added.
• History button added to child devices to display logged battery levels.
• ReTrigger button added to Health Root
• Minor bug fixes
Last version before guide was 3.0.4.3.
Last edited by SteveMSJ; December 16th, 2017 at 07:43 AM. Reason: Updated for 3.0.
Device History Plugin Release History shill Device History (3P) 18 December 3rd, 2017 10:11 PM
version history for BLRadar mnsandler BLRadar (3P) 3 January 21st, 2016 01:13 AM
Download & Version History tpchristian Sage WebcamXP 0 April 7th, 2011 12:22 PM
Download & Version History tpchristian Sage Insteon Thermostat Plug-in 0 January 23rd, 2011 01:01 PM
Version History LuxuryControl Fingerprint Reader (3P) 0 January 6th, 2007 04:11 PM
