I just migrated my HS3 server from Windows to Linux on an Odroid XU4 board. It's running on Ubuntu 17.10. I have seen a problem that after a period of minutes to hours, the Homeseer process starts eating up the CPUs to the point it crashes the system. The HS3 process normally idles at 8-30%, but it will spike and stick at 160%+, and if I leave it alone, spike to 350%+, until the system eventually overheats and shuts off.
Took me a week, but looks like after disabling every single plugin and script one by one, it's being caused by the Nest plugin. I have run this test a few times, it will run for over a day absolutely fine, then as soon as I enable the Nest plugin it'll eventually fail.
Enabled Plug-Ins
Anyone else see this? I am 99% certain it's being caused by the Nest plugin, but can't figure out why or how to debug. Once it gets into this state, stopping the plugin doesn't work, I have to stop HS3 and restart the process. I don't see any errors in the HS3 log from Nest at all. I didn't observe any issues when on the Windows box.
-Mike
- Observed on HS3 versions .368 and .398
- Plugin version 3.0.0.28
Enabled Plug-Ins
- 3.0.6.23: Insteon
- 1.5.0.0: MQTT
- 3.0.6551.16959: UltraGCIR3
- 3.0.6516.32486: UltraLighting3
- 3.0.6104.19146: UltraRachio3
- 3.0.1.179: Z-Wave
-Mike
