Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HomeSeer Voices
HomeSeer Voices Discussions related to the HomeSeer add-on voices and their use within HomeSeer.
Old November 14th, 2015, 02:19 PM
amr42's Avatar
amr42 amr42 is offline
Seer
Help needed to eliminate startup error
I get this error when HS3 Pro starts up:
The Window title is: Speaker
Error initializing Voice recognition, probably not installed, check your Speech control panel: Exception from HRESULT: 0x8004503A
I have checked the Speech properties and Microsoft Sam is selected and working.
When I click OK on the error dialog I get the HS startup spoken and port number spoken fine.
Any ideas?
Old November 14th, 2015, 06:35 PM
Rupp's Avatar
Rupp Rupp is offline
OverSeer
This error indicates an issue with your voice recognition on your HS server. Check to see if voice recognition (VR) works via the control panel > speech recognition.
-Rupp
Old November 14th, 2015, 07:46 PM
DSteiNeuro DSteiNeuro is offline
Seer Master
Location: Audrey Land (Somewhere near San Diego CA USA)
I get this if a microphone isn't plugged in and the server speech recognition is on
Tags
error, speaker
HTML code is On
Startup Error: Startup.vb: could not find library 'Scheduler.dll' - Solution centerisland HS3 / HS3PRO Discussion 12 January 2nd, 2017 09:57 AM
Error creating global variable and other startup error phuz HS3 / HS3PRO Discussion 1 January 25th, 2015 03:37 PM
Eliminate Light Bulbs Wadenut HS3/PRO Beta Releases 7 March 22nd, 2014 08:14 AM
Can't Eliminate Sprinkler Zone taschwartz MCS Temperature 0 August 13th, 2003 06:51 PM
Eliminate TV/Game option davistw Web Server and Interface 1 March 16th, 2002 08:46 AM
