Thanks for this really nice script Jon!!
Jon00 Links For Homeseer 3
Guest
Error running the links.vben
I have installed everything, added ScriptingReferences=System.Web;System.web.dll into the settings.ini (it was not there before)
Running the Jon00Links.vben gives me these errors in the log:
Apr-14 15:41:39 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\Jon00Links.vben: 'HttpUtility' is not a member of 'Web'.
Apr-14 15:41:39 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\Jon00Links.vben: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
I was just trying it, I've seen the entry was gone. No error now when I run the script. But its still showing the old links under view.
This is my Jon00Links.ini (the parts I have added too)
[Settings]
Delay="0"
FadeIn="0"
TextLinkMode="1"
LogoBarXTextPosition="650"
LogoBarYTextPosition="-66"
LogoBarTextColor="white"
[View]
Enabled="1"
1Title="Device Management"
1URL="/deviceutility"
2Title="Device Status"
2URL="/Status"
3Title="Events"
3URL="/Events"
4Title="Energy"
4URL="/Energy"
5Title="Log"
5URL="/EventLog"
6Title="ini Editor"
6URL="/Jon00IniEditor.asp"
7Title="Alexa helper"
7URL="/Jon00Alexa.asp"
8Title="Event list"
8URL="/Jon00EventViewer.asp"
9Title="Event log"
9URL="Jon00EventList.asp"
Jon:
I am still getting the error message that Mike got last week:
Error
Error
Error
Error
Error
Error
Event
Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/Jon00Links.vben
Event
Event Trigger "Test Run HS3 Jon00 Links"
Event
Event Test Run HS3 Jon00 Links triggered by the event page 'Run' button.
I shut down HS3. I took out the code :
ScriptingReferences=,System.Web;System.web.dll
Then readded it and saved it. Then restarted HS3. Cleared the cache and still that error.
This shouldn't be that hard to do. Any suggestions?
[Settings]
Delay="0"
FadeIn="0"
TextLinkMode="1"
[View]
Enabled="1"
2URL="/Status"
3Title="Events"
3URL="/Events"
4Title="Energy"
4URL="/Energy"
5Title="Log"
5URL="/EventLog"
6Title="Device List"
6URL="/Jon00DeviceList.aspx"
7Title="Event List"
7URL="/Jon00DeviceEvent.aspx"
8Title="Grouping"
8URL="/Jon00Grouping.aspx"
9Title="Web Page"
9URL="/buildpage.asp?val=2ndFloorTest"
Apologies if this has already been asked but I did search the thread and the docs to no avail. When accessing my homeseer server outside of my home network the links do not appear. I have a web redirect setup homeseer.domain.com and it points to my external IP and the port number. Homeseer loads fine in the browser but all original menus. What do I need to do to get it working externally? Thanks.
I installed the Jon00WebpageBuilderHS3 files on my HomeTroller SEL. I am running HS3 Standard Edition 3.0.0.548 (Linux). I have 5.20.1.19 installed also. When I go to the Buildpage.aspx page nothing loads. I get a back page. Originally I got the 404 error so I updated the vbnc script modification described in this thread and that took the 404 error away, but I just get blank page.
