I installed a bunch of WD200+ switches and I'm not able to get any of the switches to change the color of the LEDs to red (or any color) if my front door is unlocked. :-( I've attached what I think should be the correct code, but frankly I don't have any idea. Documentation is lacking. Does anyone have any ideas?
WD200+ Smartthings webCoRE
We are currently working on a video (Part 2) on using the WebCore and controlling each individual LED. Right now we have Part 1 done and instructions are located here: http://helpdesk.homeseer.com/article...-handler-wd200
If you have any questions feel free to contact support.
Guest
Originally posted by Userid View PostI installed a bunch of WD200+ switches and I'm not able to get any of the switches to change the color of the LEDs to red (or any color) if my front door is unlocked. :-( I've attached what I think should be the correct code, but frankly I don't have any idea. Documentation is lacking. Does anyone have any ideas?
I'm new to the forum, but I read it a lot, including Webcore Forum too, so I think in your code, there are some mistakes. I will try to help you.
First, I try to always user triggers on If conditions, and remove on your code the when true and when false
if (your door lock) changes to unlock
then
change or run something
else (when it changes to lock)
So I rewrite your code:
According to the manual of WD200+ it shows:
When any LED is set, the switch to put into status mode. When all LEDS are set to OFF, the switch goes back to Normal mode
So I think we can rewrite the code:
I think it will work. I still don't have WD200+ and WS200+ to test the code for you but I will be on USA on April (Vacation) and I will buy some!
If you have any problems, there is a forum for Webcore. I think they can help you more than me!
See you!
Another think that I found:
When you open the window to add a new task on the DO setence, there is a menu to add an integer number, and add 3 of them:
Allan
