I've had the WD200+ installed for about a week, now. Initially, it was controlling three dimmable LEDs in a ceiling fan, but they would never completely go off. So, I replaced them with three incandescents, which do go completely out, but now I've noticed that if I set the percentage to anything greater than around 87%, the dimmer "loops", that is, it goes to full intensity, then drops to approximately 50%, then 0%, then ramps back to 100%, and continues doing that until I tap "off", or set the dim value below 85% in HomeSeer or ImperiHome. It does this whether the value is set via pressing the"brighter" paddle, or remotely through HS.
Any ideas? I did not break off the heatsink tabs, by the way.
Sent from my P01MA using Tapatalk
