I'll keep it very simple. Great work.
EnvisaLink DSC Plug-in - HS3 Beta Testing
Probably asking for something that isn't possible but ... Is it possible to have an option to create the bypassed device *only if* the zone is bypassed? I like that I can now check if zones are not-bypassed (active), but it gets a little busy on the devices page with a lot of zones - I currently have 46 zones. You guys feel free to skewer me if this request doesn't make sense.
Zone Bypassed - EVL3: only supported ... 1.12.182
Hi Spud,
My EVL3 is currently on 1.12.180 and I can see the Bypass button on my devices. The EVL forum mentions a FW update on January 30th 2017 of 1.12.180.
Was .182 a mistype?
BTW, thanks for "User Access" string is now set to "Armed by System" when the system is armed from HomeSeer.
Was .182 a mistype?
Originally posted by automateme View PostProbably asking for something that isn't possible but ... Is it possible to have an option to create the bypassed device *only if* the zone is bypassed? I like that I can now check if zones are not-bypassed (active), but it gets a little busy on the devices page with a lot of zones - I currently have 46 zones. You guys feel free to skewer me if this request doesn't make sense.
Spud, don't know if it's related to the Beta release, but when I bypass a zone, I get the following error and the "Bypassed" status does not show up on the coresponding device. The panel does show the zone bypassed though
Feb-23 2:16:48 PM Device Control Device: EnvisaLink Security Office Exterior Door+Window to Bypass (-1000) by/from: CAPI Control Handler
Feb-23 2:16:17 PM EnvisaLink WARNING Unknown command value = 680
Feb-23 2:15:42 PM EnvisaLink WARNING Unknown command value = 680
Originally posted by automateme View PostSpud, don't know if it's related to the Beta release, but when I bypass a zone, I get the following error and the "Bypassed" status does not show up on the coresponding device. The panel does show the zone bypassed though
according to the docs 680 means "The whole system is in installers mode. If you did not enter Installers through the TPI, you will be locked out of most options"
so if you should probably exit installer mode...
Originally posted by spud View Postwhich EnvisaLink board do you have EVL3 or EVL4? and which firmware does it run?
EDIT: Just reading a few posts up. I guess that I won't be able to see the Bypassed/Active status until my EVL3 gets updated to 1.12.182.Last edited by automateme; February 23, 2017, 08:57 PM.
I updated to the latest version and I must be missing something. I have the bypass checkbox checked, but I am not seeing the devices. I am on the EVL4.
What am I doing wrong?
Also I deleted my zones I am not using, and now get this error, and can't get into the config page of the plugin
Feb-24 8:56:52 AM EnvisaLink ERROR Error: Object reference not set to an instance of an object.
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 30
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 29
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 28
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 27
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 26
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 25
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 24
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 23
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 22
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 21
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 20
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 19
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 18
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 17
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 16
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 15
Feb-24 8:56:37 AM EnvisaLink ERROR Cannot find zone 14
Originally posted by waynehead99 View PostI updated to the latest version and I must be missing something. I have the bypass checkbox checked, but I am not seeing the devices. I am on the EVL4.
for the "zone bypassed" devices to be created, you need to make sure the "Do not recreate missing devices" is not ticked, and then tick "Create additional devices for zone bypassed status".
Originally posted by spud View Postplease test version 3.0.0.33 that I just posted at the beginning of this thread, this should fix the error you see when you try to access the config page
Config page also working again. Thanks for the quick turn around.
