Find my iPhone plugin for HS3
    Originally posted by jrhubott View Post
    Must be the commas instead of the decimal point throwing something off. I will look into it tonight.
    Sent from my iPad using Tapatalk HD
    It is. I have had it before. Rdp is als from the netherlands so probably uses comma as decimal sign. I 'fixed' the issue by changing from comma to point
    Verstuurd vanaf mijn Nexus 5 met Tapatalk
      Okay thanks, and what about the reverse GeoCode issue ?
      Rien du Pre
      The Netherlands
      Using:
      Plugin's:
      RFXCOM, mcsMQTT, Z-Wave
        Any chance you have two factor authentication turned on in your apple account? It doesn't make sense that you are getting emails that it logged in but the errors you are getting are failed authentication.
        I don't know but I will look into it tonight. Thanks.
          Try the new version I just pushed to the updater and see if it works.
            The new version is great in that you can select which devices to track. Thanks for that.
            Now, it did not seem to update after creating the devices, but after stopping and restarting the plugin, it is now updating, although we have not moved any to see if subsequent updates are working.
            It does seem that the battery device now reads 0 percent though. Possible bug?
              Dumb question:
              Which type of API Key should be created? Server, Browser, Android or iOS are the choices. I know we are trying to track an iPhone but not sure if it should be a server or iOS key etc.
                OK, it's definitely not updating. Away from home for a few hours, icloud shows the update, but HS still shows at home. Cycling the plugin seems to force a single update, but then it stops. FYI, this is with no Googlr API key defined. The plugin should work and update longitude and latitude even without that though. I have no interest in using Google.
                  Originally posted by Digger1 View Post
                  Dumb question:
                  Browser key. I will add that to the instructions on the page.
                    Thank you sir. Try it shortly.
                      Ok I think its working. Update rate is 60 minutes and I get an email every 60 minutes every time when it updates.
                      So how are people displaying to location of the phone on a map etc?
                        I have my update rate set to 3 minutes and it never updates after the first time.
                          I'm not seeing that. I will try running it without a Google API key tomorrow morning. I don't think that will be a problem but I will look into it.
                          If possible can I get you to email me logs if I can't figure it out?
                          Jason
                            Hi all
                            Can someone kindly confirm that I have these set up properly? There seems to be a couple of minutes delay between the "geocache " event triggered by the kitchen motion sensor and the "cctv" event actually running.
                            Is it anything to do with polling the "home " status or perhaps it should be " device changes to"
                            Cheers
                            SteveClick image for larger version
                            Steve
                              Tried 1.0.2.5.
                              It's dead Jim.
                              No location updates even though I get the email about it logging into my account.
                              Nothing special on the plugin screen logging with developer mode enabled.
                              I also tried to delete the devices and let the plugin recreate those. Nothing.
                                Tried 1.0.2.5.
                                It's dead Jim.
                                Please send me a logfile(HSPI_RSFindMyDevice.txt) and I will look into this. Use the following email: support@rhusoft.com
