I'm sorry if this is in the wrong section, it was difficult to work out where it should go.
Is there an existing plugin or is it possible to create a virtual device that controls an existing device on the same network as the HS3 software via Urls? I am migrating from another system and until all the devices are transferred across, it would be useful for me to tell the old system to do something with a device.
The old system (a vera plus) can have it's devices controlled via URLs, so for example, I would create a virtual device on the HS3 software for a light, when you turn it on it accesses one url, then when you turn off it accesses another url.
Is this actually possible?
Thanks in advance for your help!
