Update to 3.0.0.14 failure FYI
    I tried to update from 3.0.0.11 to 3.0.0.14. I got a message on screen "Install/Update of package Homeseer Netcam failed. Log showed ...Copying source to C:\Program Files (x86)\HomeSeer HS3\HSPI_NETCAM.exe, detailed error: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\HSPI_NETCAM.exe' because it is being used by another process. Manually disabled NetCAM and was able to update it then.
    I am getting a similar error when trying to update netcam
      Disable the Netcam plug in, then update, then enable it.
        Yes I discovered this with others as well. So now I always disable the plugin first, update it, then re-enable it as a regular process.
        Robert
          That worked like a charm thx
