I have two of these locks, I add them to my server using the Z-wave plugin.
No issues adding it, but for some reason the 2 identical lock aren't getting the same configuration...
One the manufacturer is saw has Assa Abloy (ID=0x129) with application version 33.32
The other the manufacturer is saw has Vision Security (ID=0x109)
with application version 25.24
And this is the same lock, maybe the Z-wave module is different, but when I was on Vera, I could see those two identical and the settings are the same.
Now in HS3 the settings I have them all in the first lock, but they are not present in the second lock (operating mode, audio mode, language, autolock mode, tamper threshold and tamper lock period) are not there!
So, why is that? And could I manually change the ID of the second lock to put it just like the first lock? Because I know that all those options was functional on the second lock just like the first lock...
Joel
Joel
