Does anyone know how I can make a replacement value which provides a timer value that is separated with colons (example 1) into a more readable format preceded with Days, Hours, Minutes (example 2)? I've provided an event example (example 3) any help would be greatly appreciated. Mike
Virtual Device String Formatting
Computer: CUK Intel NUC7i7BNH
Op System: Windows10 Pro - Work Station
HS Version: HS4 Pro Edition 4.2.19.0
Plug-Ins: AK Weather 4.0.5.25,APCUPSD 3.3.2.3,BLBackup 2.0.63.0,BLEditor 2.0.11.0,BLGData 3.0.55.0,BLOccupied 2.0.28.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,Device History 3.2.0.2,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,iRobot 5.22.41.1,JowiHue 4.0.8.7,Nest 3.0.0.34,NetCam Plugin 1.0.0.5,PHLocation2 3.0.0.64,Pushover 4.0.10.0,Random 3.0.0.2,Restart 1.0.0.7,Ring 1.0.0.9,SDJ-Health 3.1.1.3,Sonos 3.1.0.59,Sonos4 4.0.1.12,UltraCID3 3.0.6681.34300,UltraMon3 3.0.6554.33094,UltraNetCam3 3.0.6413.20219,Unifi 4.0.32.0,Zigbee 4.0.11.0,Z-Wave 4.0.3.0, and Jon00 scripts.Tags: None
I'm not aware of any replacement variable that will do that. It's deceptively difficult. This script may do what you want. Replace 1092 with the Ref ID of your timer device and 1388 with the Ref ID of your target device.
Code:Public Sub Main(ByVal Parms As Object) Dim strTimer As String = hs.DeviceString(1092) Dim strFriendly As String = "" Dim strD As String = "" Dim strH As String = "" Dim strM As String = "" Dim strS As String = "" Dim I As Integer Dim strValues As String() Dim strSeparators() As String = {":"} strValues = strTimer.Split(strSeparators, StringSplitOptions.None) I = strValues.GetUpperBound(0) If I > 2 Then strD = strValues(I-3) & " days " If I > 1 Then strH = strValues(I-2) & " hrs " If I > 0 Then strM = strValues(I-1) & " mins " strS = strValues(I) & " secs" strFriendly = strD & strH & strM & strS hs.SetDeviceString(1388, strFriendly, True) End Sub
Originally posted by Uncle Michael View PostI'm not aware of any replacement variable that will do that. It's deceptively difficult. This script may do what you want. Replace 1092 with the Ref ID of your timer device and 1388 with the Ref ID of your target device.
@Michael, the script snip-it worked great and now does what I wanted Thanxs for the support. MikeComputer: CUK Intel NUC7i7BNH
@Michael, I thought I would be clever and make the script snip-it as a universal script where I could enter both the timer and virtual device IDs within the Event parameter field but I seem to not fully grasp scripting, per chance could review and advise what I'm doing wrong? Mike
Dim ParmArray() as String
ParmArray = Parms.tostring.split(",")
Dim tTimer = ParmArray(0)
Dim tDevice = ParmArray(1))
Dim strTimer As String = hs.DeviceString(tTimer) 'Ref ID of Timer
Dim I As Integer
hs.SetDeviceString(tDevice, strFriendly, True) 'Ref ID of Target Virtual Device
End SubLast edited by MNB; March 18, 2018, 01:10 PM.Computer: CUK Intel NUC7i7BNH
OK this is getting dangerous - and inelegant.
Here's an attempt, but I have not tested it very thoroughly. It uses the same separator for both the reference ID input and the timer contents, so it assumes you separate the two Device IDs with a colon [:].
I'm sure there are better and more compact ways to do this, but I'm only a hack at writing scripts.
Code:Sub Main(ByVal Params As String) Dim strTimer As String Dim strFriendly As String Dim strD As String = "" Dim strH As String = "" Dim strM As String = "" Dim strS As String = "" Dim tTimer As Integer Dim tDevice As Integer Dim I As Integer Dim strSeparators() As String = {":"} Dim strValues As String() Dim strIDs As String() strIds = Params.Split(strSeparators, StringSplitOptions.None) tTimer = CInt(strIDs(0)) tDevice = CInt(strIDs(1)) strTimer = hs.DeviceString(tTimer) strValues = strTimer.Split(strSeparators, StringSplitOptions.None) I = strValues.GetUpperBound(0) If I > 2 Then strD = strValues(I-3) & " days " If I > 1 Then strH = strValues(I-2) & " hrs " If I > 0 Then strM = strValues(I-1) & " mins " strS = strValues(I) & " secs" strFriendly = strD & strH & strM & strS hs.SetDeviceString(tDevice, strFriendly, True) End Sub
Originally posted by Uncle Michael View PostOK this is getting dangerous - and inelegant.
Originally posted by MNB View PostOut of curiosity why did you use ":" vs "," as the parameter separator? MikeMike____________________________________________________________ __________________
Originally posted by MNB View Post@Michael, many thank-you for the update, I will try it later this evening and confirm. Out of curiosity why did you use ":" vs "," as the parameter separator? MikeComputer: CUK Intel NUC7i7BNH
Originally posted by MNB View PostI'm not getting the formatted timer value but instead the state text,
How are you entering the Ref IDs in the event? Does it look like this?Mike____________________________________________________________ __________________
Originally posted by Uncle Michael View PostWhat do you mean by "state text"?
How are you entering the Ref IDs in the event? Does it look like this?Computer: CUK Intel NUC7i7BNH
@Michael, thanxs for the comeback.. I was able to look at what had I pasted from your post into the .vb file and found some space characters within the text (something I did), after removing them I was able to get my Virtual Devices to properly display the correct formatted time values.
I normally use a LUA editor (Zerobrane) when developing/modifying scripts as it does basic code format & content checks to avoid any issues which I did not initially, hence the space characters. Needless to say, problem fixed and am now running as anticipated, and traded three separate scripts for a single script. Many thanxs MikeLast edited by MNB; March 19, 2018, 10:01 AM.Computer: CUK Intel NUC7i7BNH
