I have installed a new HS3 instance and installed your plug in. The log file is showing a repeated disconnect and reconnect. I had your plug in working in HS 2
Apr-27 4:43:35 PM EnvisaLink ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. Apr-27 4:43:35 PM EnvisaLink INFO Reconnection OK Apr-27 4:43:35 PM EnvisaLink INFO Trying to reconnect to: 192.168.199.33:4025 Apr-27 4:43:24 PM EnvisaLink INFO Connection Lost, will try to reconnect in 10 seconds Apr-27 4:43:24 PM EnvisaLink ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. Apr-27 4:43:24 PM EnvisaLink INFO Reconnection OK Apr-27 4:43:24 PM EnvisaLink INFO Trying to reconnect to: 192.168.199.33:4025 Apr-27 4:43:13 PM EnvisaLink INFO Connection Lost, will try to reconnect in 10 seconds Apr-27 4:43:13 PM EnvisaLink ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. Apr-27 4:43:13 PM EnvisaLink INFO Reconnection OK Apr-27 4:43:13 PM EnvisaLink INFO Trying to reconnect to: 192.168.199.33:4025 Apr-27 4:43:02 PM EnvisaLink INFO Connection Lost, will try to reconnect in 10 seconds Apr-27 4:43:02 PM EnvisaLink ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. Apr-27 4:43:02 PM EnvisaLink INFO Reconnection OK Apr-27 4:43:02 PM EnvisaLink INFO Trying to reconnect to: 192.168.199.33:4025 Apr-27 4:42:51 PM EnvisaLink INFO Connection Lost, will try to reconnect in 10 seconds Apr-27 4:42:51 PM EnvisaLink ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. Apr-27 4:42:51 PM EnvisaLink INFO Reconnection OK Apr-27 4:42:51 PM EnvisaLink INFO Trying to reconnect to: 192.168.199.33:4025 Apr-27 4:42:40 PM EnvisaLink INFO Connection Lost, will try to reconnect in 10 seconds Apr-27 4:42:40 PM EnvisaLink ERROR Receiver::Run() A socket error has occured: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. Apr-27 4:42:40 PM EnvisaLink INFO Reconnection OK Apr-27 4:42:40 PM EnvisaLink INFO Trying to reconnect to: 192.168.199.33:4025 Apr-27 4:42:29 PM EnvisaLink INFO Connection Lost, will try to reconnect in 10 seconds Apr-27 4:43:35 PM EnvisaLink INFO Connection Lost, will try to reconnect in 10 seconds
