airplay error
airplay error
Last edited by Malosa; April 30, 2016, 10:38 AM.Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.Tags: None
Hi spud ,
Its an ezcast m7
IT works really Well using iT normal , but your plug-in is doing really weird.
After iT Speaks trough homeseer i get the Error , then i need to wait a minute , and iT can speak again , but after speak again that Error.
Looks like a time-out ,but using iT normal i can stream music without no lag
Spud ,
Maybe a stupid question , but can you integrade tuneblade into this plug-in , many people are using iT also
Here is the api
Regards
http://tuneblade.com/Developer/TuneB...API%20v0.8.pdfPreferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
hi spud ,
I installed it and I tested 2 normal events they work , but when I did try my third long event it stopped talking half way , check debug log
it does not talk anymore..
But he does that only with that long speech event.. Short speeches work normal..
This beta is much better than before , only long speechings don't work.
Delay after : 2 sec.Attached FilesLast edited by Malosa; May 4, 2016, 02:37 PM.Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
hi spud ,
here they are , the working debug log and not working log
regardsAttached FilesPreferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
Hi spud , u have any idea about this problem?
Regards
Sended from far far awayPreferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
Ok , iT only drops after a long speech , its exactly the same as the topic from virtualpanther: lenght of text announcement
