Due to heavy load on the MyHomeSeer Remote server, the server service has been re-written. The re-write greatly improves performance and reliability. The change however requires a change to the HS3 application. To further use the service you must update your HS3 installation as follows:
* If you are using HS3 version 3.0.0.96, you can update to 3.0.0.97, which is available here:
Download HS3 release 3.0.0.97
* If you are using a later version, you can update your Beta to version 3.0.0.143 or later, available here:
Latest HS3 Beta
If you are using a HomeTroller SEL or Zee, go into Setup and click the "Check for Updates" button to get the latest version. You need version 3.0.0.141 or later.
Latest HS3 Beta
