Was wondering if this plug-in can work with a ted pro? Trying to find a solution for monitoring multiple circuits in the box.
Ted Pro
Originally posted by Blade View PostIt should... I am planning on getting a TED Home pro system very shortly so I will be fine-tuning the plugin once I get it going
Guest
TED PRO
I have a TED PRO system with 2 spyder devices (planning on adding another mtu and 2 more spyders soon). I have setup the BLTED plugin and it appears to see my MTU, but it doesn't show any of the spyder device information.. is this supported?
also, the MTU data that it does show doesn't appear to be usable by HS3's view->energy graph (no devices show up there)
I noticed the plugin has the Pro now in the drop down box under 'add gateway'...does that mean it is supported or was that just a placeholder? I have the older TED, the 1001 that uses USB and their Footprints software...I assume there is no support for that? My only option looks like finding a TED5000, there are still some refurbished ones left with the manufacturer.
