Solved!
Hi all ,
i dont know what i forget but i cant get this specific line to work in my script.
This is a piece of a script im writing for hs3.
I converted from bat to vb .
this is the original line :
this wil make a zip file of C:\Program Files (x86)\test1\ and put it into D:\HS3B\
But when i try to run this script it says its missing a comma or a )
so i changed it to :
And it doesnt work, it says directory invalid..
does anyone know what i'm missing ?
thanks in advance
Hi all ,
7zG a -tzip "D:\HS3B\test.zip" "C:\Program Files (x86)\test1\*" -mx5
PHP Code:
Imports System.Diagnostics
Imports System.ComponentModel
Sub Main(parm as object)
Process.Start("CMD", "/k 7zG a -tzip "D:\HS3B\test.zip" "C:\Program Files (x86)\test1\*" -mx5
end sub
Process.Start("CMD", "/k 7zG a -tzip D:\HS3B\test.zip C:\Program Files (x86)\test1\* -mx5")
thanks in advance
