My craftsman garage door was on its last legs so I replaced it with this one model 55918.
I can't seem to get my GD00Z to send the right signal to the garage door opener. Here's what I did:
1. disconnected the GD00Z and brought it next to my Z-NET
2. Plugged it in and started the remove node process which completed successfully
3. Hit the pair button on the GD00Z 5 times quickly to factory reset it, which I received the confirmation beep that it worked.
4. Started the pairing process with HS3 and hit the pair button on the GD00Z. Paired successfully with the security schema that often is an issue. Worked fine.
5. Went back to the garage and connected the GD00Z to the garage door opener.
6. Opened and closed the garage door from the wall controller
7. Tried to open from HS3 - here's what happens:
- The GD00Z gets the command from HS3 and flashes the strobe light and beeps.
- "Some" command is sent to the garage door as I can see the up LED arrow on the garage door flash and hear a click from the garage door
- Door doesn't open or close
It seems like the GD00Z needs to be programmed to send the right command to the garage door to control it.
Also worth noting, the original craftsman wall controller panel didn't work with the new garage door. I had to use the new wall controller that came with it. The symptoms were identical with the old wall controller. I'd hear a click and see the arrow flash - but nothing.
Any ideas? Appreciate the help.
